Question about Onkyo TX-SR505 Receiver
TX-SR504 receiver won't turn on
Receiver quit turning on. Now nothing connected to it. No lights. Hear a click but won't turn on.
Posted by sschmidt49 on
  • giants135 May 12, 2009
    I am having the same problem. When I plug my 505 in, it makes a click after a few seconds, and then another click a few seconds later. It will not turn on, and makes no indication that it is even plugged in other than the clicking noise. Any way to elaborate on your explaination? Any information would be helpful. pvt mail: [email protected]. Thanks
wernersaurus
Had same on an ONKYO TX-505 given to me for repair - eventually found a broken track on top circuit board that came from a transistor that control the main power on relay - looked like it was burnt off for a section of about 1.2mm
Repaired the track and has worked ever since
good luck WTech/Townsville
Posted on Apr 29, 2009
How do I connect my ipod classic to my onkyo tx-sr504 audio/video receiver?
Onkyo DS-A2
iPodĀ® dock
http://www.crutchfield.com/p_580DSA2/Onkyo-DS-A2.html?tp=238
Jul 11, 2014 | Onkyo TX-SR504 Receiver
How do I connect my Ipod classic to my onkyo tx-sr504 audio video receiver ?
Perhaps you just use a cable like this:
24806182-o2xiqwfhpbqb50rejnrszwmj-1-0.png use the tulip plugs and plug them into the AUX of the amplifier. Then at least you can play the music via the receiver.
Jul 11, 2014 | Onkyo TX-SR606 Receiver
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Wire Kenwood GE 7030 equilizer to onkyo tx sr504 receiver
The manuals explain it.
http://www.retrevo.com/support/Kenwood-GE-7030-manual/id/479dj189/t/2/
http://www.retrevo.com/support/Onkyo-TX-SR504-Receivers-manual/id/365ag215/t/2/
For all practical purposes an EQ or any analog audio processor connects exactly like a Tape Deck - into any RCA pairing that has both an OUT and an IN and can be selected to be in or out of the audio path.
However, on this and just about any modern digital-capable AV Receiver, activation of any external loop that would connect a processor or tape deck would automatically DISable any digital audio sources. The effects of the processor, therefore, can only be used with analog stereo sources. It WILL affect the sound going to all speakers if you use the various Digital Sound Porcessing modes as the extra channels are derived from the stereo channels anyway.
Sep 30, 2011 | Onkyo TX-SR504 Receiver
Sound cuts out especially when commercials come on. I turn off receiver then turn back on and the sound is back.
Sounds to me like you may need to turn off the 'Smart Sound' feature as this sometimes malfunctions causing the sound to turn down to almost nothing, and sometimes nothing at all. 'Smart Sound' is a feature that keeps a units volume from going way up when commercials come on... A lot of advertisers have it set to where their ads are broadcast a bit, sometimes quite a bit louder, that the normal broadcast, they do this to ensure you hear their ads... Hope that's all it is, Best of luck!
Sep 16, 2009 | Onkyo TX-SR601 Receiver
Onkyo tx8511. Receiver working fine, power went out
Is channel B switch turned on? If so turn it off .
Feb 27, 2009 | Onkyo TX-8511 Receiver
Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Nov 09, 2008 | Onkyo TX-SR605 Receiver
TX-DS575 reciever
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
Jul 04, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-SR505 Receiver Logo
591 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
