While using the lawn edger, all at once the cutting blade started going backwards. I can turn the blade forward and backward, but when plugged in, the blade only goes backward. I have tried using different outlets and different cords and it doesn't make a difference.
SOURCE: Cratsman lt2000 lawn tractor will start but will
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
SOURCE: Was mowing when it just stopped going forward. It
Under the mower below the seat of the rider, at the rear of the tractor, look up and you will find the transmission there. There is a belt that runs on the pulley under there, and this belt can slip off when it gets worn or stretched. Sort of a tough spot to get to but, that is most probably cause.
Let me know,
Chip
SOURCE: My orbit tractor lawn sprinkler
try turning the nozzles the other way - they should turn counter clockwise when looking from the top, not clockwise.
