Iomega hard drive beeping
SOURCE: My Iomega hard drive (MDHD-UP) not working, only beeps
Hi, Generally the HDD inside the shell can handle about a 6' drop when it's off and about a 1' drop if it's active. The beep is most likely coming from one of the shell components. Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may have been actively reading/writing when it toppled and as the drives are a lot more delicate during that process you may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
SOURCE: solution CD for Iomega Network Hard drive 250Gb
You get the drivers at Iomega.com and look under support to get your drivers.
REMEMBER you need to install those drivers to ONE pc and then have all your computers networked to it thru your network neighborhood. Any other questions, please write back to me, ok?
SOURCE: my iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
SOURCE: I have a 320 gb iomega external hard drive it
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external ,
go to Start-Control Panel-Administrative Tools-Computer Management-Disk
Management , and see if your external drive is listed here with your
local drives. If it is listed , right click on the drive and change the
drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your
computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your
computer case or another external case.If the drive works , the problem
is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
The
latter is the easiest to diagnose , does your external light up at all
when you plug in the power? If not , then this is probably your problem.
On the bottom of the adapter is a label which you will be able to use
to have a new adapter made at your local electronics shop and this will
cost about $30 max. They will also be able to test the adapter with a
clamp meter to see if this is really the problem and this should be
free.
The second component you want to test is the USB cable. If
you have a printer , swop out the cables and see if your printer
functions normally. Most externals use the same connector so you should
be able to test it in this manner. If the cable works go on to the last
step. If the cable is defective , replace it with a new one which you
can find for about $10 at most electronics and chain stores.
The
last component to test is the circuit board. This is a bit of a grey
zone as you probably won't be able to spot the blown component unless it
failed really badly. With the casing already opened , locate the
external's circuit board and check to see if you have any blackened
components or fluids leaking from some components. If all the other
components of the external worked perfectly , then this is the faulty
part. It is not really economical to replace the circuit as most of the
time it is out of production by the time you need to replace it and it
still costs a lot even if it is available so if your drive is working
perfectly when connected via sata or IDE on your computer , the best is
to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
