Question about DISH Network ES190482 Remote 40.0 ES190482
HELP!!!! Dish remote 40.0 isnt fully controling Apex tv LD4688T ?
When I press tv button on remote most things work on tv using dish remote like the volume & channel, however when I try to change the tv input from hdmi to AV the remote does not let me move up or down in that menu to change the input with remote. I have already disabled limited mode on remote. What is the problem?
Posted by Aimee Smart on
Prasanna
    Master:
  • 879 Answers
Try an other code. Setup the remote control for an other code to Apex brand. If you wish to get more details, check this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. More than Ten Lakh viewers cannot be wrong.
Posted on May 20, 2013
5 Related Answers
Anonymous
  • 336 Answers
SOURCE: dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
Posted on Sep 16, 2009
Chi Chu
  • 8457 Answers
SOURCE: both remote controls for tv1
Tries Dish network box unplug,replug the box back like an hour later.By letting the box itself rebooting and upgrading it softwares,should solved this problems.If not than the box have problems.Trade in for a new box.
Posted on Dec 06, 2010
NickF DISH
NickF DISH
  • 36 Answers
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record.
Hope this helps!
Posted on Jan 03, 2011
DishnoutonU
SOURCE: my remote control only works
I experienced this problem as well. I have a dual receiver and had issues turning channels on TV2; but counld easily access the volume. After reading the Dish manual, I learned that my TV1 and TV2 remotes connect through different signals (IR = infrared for TV1; and UHF= ultra-high frequency for TV2).
Check your remote to see if there is a UHF logo at the very bottom (under the Dish Network logo). The UHF remote sends ultra-high frequency radio signals to a UHF antenna which is connected to the back panel of the receiver. Make sure that you receiver is properly dusted and then check to make certain that the UHF antenna located on the back of the receiver is positioned straight-up. When the antenna is not correctly positioned it can cause problems with your remote signals.
Posted on Jan 09, 2011
kimberlyesco
Dish
  • 184 Answers
    Verified Fixya Pro
    SOURCE: can't get the tv/input button to work on dish
    Hi there! This is Kimberly Escobar with Dish Network. Just ran across your post and wanted to help. In order to get the remote to possibly work the Inputs on your T.V the remote needs to be programmed to your Vizio T.V. In order to do this we have certain codes that can be integrated into the remote. Some of the codes for a Vizio T.V are 505, 671, and 627. The procedure is press and hold the clear T.V buttton located at the top of your remote until you see all the other buttons light up in red, once they are lid up enter one of your codes followed by the pound key for example: 505#. The T.V button should light up 3 times you can then try the remote to see if it works your T.V
    Unfortunately we cannot promise it will completely function the T.V so it might bu that input button does not work. If you need any help please contact us directly at 1800-333-DISH.
    Posted on Feb 09, 2011
    Trying to set DISH remote for an APEX LD4088. need the code please
    Hello chiech22,
    I noticed your post and see that your DISH remote needs to be programmed to your APEX TV. There are a couple of ways that your remote can be programmed to your TV. One option would be to use the remote code that is for your TV, these codes may vary depending on the model of your remote. The best option for you would be a Power Scan to get your remote programmed to your TV. Here are the steps.
    1- While at the TV locations (TV1 or TV2 depending on which key is installed), point the remote at the TV. Press and hold the TV MODE button on the remote until all four MODE buttons at the top of the remote light up.
    2- Press the RECEIVER POWER button on the remote.
    3- Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the TV turns off. This process may take several minutes.
    4- Press POUND (#) on the remote. The TV MODE button will flash three times.
    5- Press TV POWER on the remote to turn on the TV. Press VOLUME on the remote to confirm the remote controls the TV. If this does not work, return to Step 1.
    If you need any further assistance let us know. I hope this helps.
    Jul 24, 2011 | DISH Network IR Remote Control
    I have dish network and an apex 1225 dvd player. i do not have a remote for the dvd player. i do however have a dish network platinum remote control. i am in need of the code to link this remote control to...
    Try the steps below these processes are called a power scans, there is a different type for any equipment needed. This should take 5-6 minutes per item to program.
    For DVD/VCR's:
    1.) Press and hold the correct VCR/DVD button (about six seconds) until all mode button backlights come on, then release.
    2.) Press 222 pound (#) then record three times.
    3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
    4.) Press and release the Power button.
    5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
    6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
    For TV's:
    POWER SCAN
    1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
    2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
    3.) Press the channel up button once per second until the TV turns off then press pound (#).
    For any other equipment:
    Power Scan AUX
    1.) With the desired equipment on, press and hold the correct AUX button until all mode button backlights illuminate (about 3 seconds), then release.
    2.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
    Press and release the large red Power button.
    3.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
    With any of these methods verify the code works by trying several different functions for that equipment.
    Daniel Busa
    DISH Network
    Customer Service
    Mar 20, 2011 | Apex Digital AD-1225 DVD Player
    I have an Apex model LD4088 and a dish remote and cannot find the right codes. Can you help
    Hey there, Cheri Torres with DISH Network Customer Service.I came across your post recently and wanted to see if I could help. We have afew different codes for each of our different models of remotes you will beable to locate the model of your remote on the back of the remote at the topusually a two to three digit number with a decimal point. I will list here foryou the best codes for the more popular models of remotes as well as theinstructions for addressing your remote to your APEX TV. I hope you find thesecodes and instructions useful and if you have any further questions or concernsfeel free to email me at [email protected] Thanks and have a greatday!
    The codes for each model of remotes
    3.0, 3.1, 3.2 and 3.4 IR remotes - 745, 743, 595, 069 and 744
    5.0, 5.2, 5.3 and 5.4 IR remotes - 595, 006, 019, 020, 757 and 744
    20.0 IR remote - 594, 552, 815 and 017
    4.0 and 4.4 IR/UHF remotes - 744, 595, 745,743 and 757
    6.0, 6.2, 6.3 and 6.4 IR/UHF remotes - 744, 745, 595, 757, 743, 594 and 789
    21.0 IR/UHF remote - 595, 594 and 743
    Instructions for addressing remote to the TV
    1. Turn the Television On
    2. Press and Hold the TV mode button until all other mode buttons light up red.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press the pound(#) button once.
      Note: The LED will flash three times.
    5. Test functionality with the TV
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
    Feb 17, 2011 | DISH Network IR Remote Control
    Trying to set up dish network remot to apex dvd player
    dr172120,
    I'm sorry you are having problems programming your DISH Network remote to your Apex DVD player. I looked through our remote codes but I don't show we have a code for an Apex DVD player. We do have remote codes for an Apex TV. You can run a power scan to see if you can find a code for the DVD player. I have provided the instructions to conduct the power scan below. If you have any other question, please post to this site.
    Ray Calo
    DISH Network - Executive Offices
    Address To Other Equipment Using Power Scan
    • Remote: All Remotes (except Basic)
      1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
      2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
        • Press 0 for a TV
        • Press 1 for a VCR/DVD
        • Press 2 for any other device.
        Then Press STAR (*)
      3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
      4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
    Jan 14, 2011 | DISH Network IR Remote Control
    I just got a new apex 27in old style tv and my dish remote wont sync to it how can i fix this
    Hi, my name is Cheri Torres with DISH Network customerservice. I came across your post and wanted to see if I could be of assistance.DISH Network has a few different codes for all of the different models ofremotes that we have. The remote model number is located on the back of theremote at the top, usually a two to three digit number with a decimal point. Iwill list here for you the codes that work the best for APEX TVs for the mostcommon models of IR and IR/UHF remotes that we have and also the instructionsfor addressing your remote to your TV. For the 3.0, 3.1, 3.2, 3.4 IR remotesthe best codes are 745, 743, and 757. For the 5.0, 5.2, 5.3, 5.4 IR remotes thecodes are 757, 744, and 593. For the 4.0, 4.4, 6.0, 6.2, 6.3, and 6.4 IR/UHF remotesthe best codes are 744, 785, and 595. For our newest remote the 20.0 and 21.0the best codes are 595, 594, 743, and 552. I hope you find these codes andinstructions useful in addressing your remote to your TV. If these codes do notwork or if you have any further questions or concerns feel free to post backhere or email me at [email protected]
    Cheri Torres
    DISH Network customer service
    [email protected]
    Instructions for addressing remote to TV
    1. Turn the Television on.
    2. Press and Hold the TV mode button down until all the mode buttons (i.e AUX, SAT etc.) light up at the top of the remote.
    4. Press the pound (#) button once. Note: The LED will flash three times.
    Jan 13, 2011 | DISH Network IR Remote Control
    I have ( Apex digital LD4688 ) I neeed the code. Thank you.
    I install dish network. i have tried all versions of dish remotes, . the only one that works is Dish Network 21.0 Learning Remote. it will work with all dish products and i have programed it for this tv apex ld4688 hd and it works great.here is a link for the manual on how to use.
    http://www.satelliteguys.us/dish-network-forum/158496-dish-network-21-0-learning-remote.html
    Nov 27, 2010 | DISH Network IR Remote Control
    Need the code for apex 46 in. 1080p lcd tv for dish remote
    Hello, my name is Tommy Faust with DISH Network. I would be pleased to help you with that.
    The main codes for a Apex tv are 595, 744, and 743. Give those a try and see if they work. Feel free to ask here if you have any other questions/concerns!
    Nov 26, 2010 | DISH Network IR Remote Control
    Dish network
    Codes for Apex are 595, 618, 743, 744, 005, 006, 019, 020, 120, 745, and 757.
    Codes for Sony tv are 500, 514, 578, 640, 670, 690, and 758.
    If these dont work here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
    1)hold down tv button next to sat button in top left corner
    2) when all buttons illuminate press 500 into remote
    3)press pound sign
    4)Hello, please help..
    5)hold town tv button again.
    6)when all buttons illuminate press big red power button
    7)press up arrow once a second until tv shuts off
    8)press # pound sign
    9)try to turn tv back on w/ big red power button
    10)if tv doesnt turn back on try again from step 2 but use down arrow instead
    To set up caller id you have to enable it on the receiver. Press menu 6-1-2, highlight enable and press select. Highlight done and press select. Press 0 three times. Try calling yourself with a cell phone to see if it works, if not, repost on this thread.
    Dec 11, 2007 | DISH Network IR Remote Control
    DISH Network ES190482 Remote 40.0 ES190482 Logo
    178 people viewed this question
    Top DISH Network Televison & Video Experts
    matt martin
    matt martin
    Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
