SOURCE: Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
SOURCE: Speakers not working, but cables all plugged in...
You might have to reinstall the software that came with the speakers since you had to wipe your computer clean when the virus was on there. The speakers will not work until the software is installed back on your computer.
the problem is your computer may not sense the presence of your audio device, chances are your driver is either corrupted nor not yet installed.
go to my computer then right click go to properties, hardware, device manager,
under the device manager go to sounds and see if ther is any exclamation icon or anything , expand this icon and see if there is anything you see that has a yellow exclamation or question mark right click that icon and select scan for hardware changes , then update driver , better yet go to sound properties and see if you can roll back the driver, if you have the cd utilities for your computer, you can reinstall the driver again and after all this restart once again your computer
cheers
SOURCE: x-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
SOURCE: loss of sound to Logitech Z560
I repaired Z-560 speakers with a defective left front channel by chopping off one of the input leads close to the 3.5 mm stereo jack that goes into the PC and joining on the leads from a new one. At first I thought the fault lay in the main amplifiers in the sub woofer unit but I was wrong and it turned out to be far simpler to fix than I anticipated.
Rod in Ottawa
