working with Electrical parts "wires" is not something i would recommend unless you are an electrician but how ever i would try a new bulb first if that doesn't cure it i would take it back to your repair man who repaired it before
Keep in mind that this wire will only have voltage to it for two seconds after you turn the key on. It will take two people to check since you won't have time to run back and forth from the ignition switch to the connector to the fuel pump. Find the Fuel pump relay in the under hood fuse box and have someone turn the key on and listen for an audible click. The check for voltage again at the power wire of your connector within that ininitial two seconds. Let me know if you need further diagnosis. I've replaced quite few fuel pumps on these already. Just remember that when you turn the key on, you'll only have voltage for 2 seconds.
1) please the timer for defective, however clean the contacts very well, loose wires, or broken and repair. see the diagram attached 2)no cold water, see this and fix it. God bless you
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
did you have try to reset all the video settings ?? ok let's try that my name is Juan and I am here to help you and see if we can solve this with the unit off turn the main switch off on the back of the unit connect the HdmI cable to the unit and to the tv now place your finger on the front on/off switch and keep it there now turn the main switch on the back of the ps3 keep your finger on the on/off switch for about 4 seconds or until you heard one bip (but not the first bip when the playstation turns on ) ok so once you heard the bip after few seconds remove your finger from the on/off switch and this should make your hdmI to work again just wait few seconds for the signal to show up on your tv sometimes it takes about 30 seconds once you see the browser the system will ask you if you want to switch to hdmi click yes hope this can fix your problem and if it does please rate my help thanks
Sounds like remote turn on wire is bad. If using aftermarket HU, find another location to power amp. Try the the power antenna wire on the HU to run the REM.
You might have a faulty wire, this simply means check that all wires are in properly in the back of 360! If this still happens you can send it into a gaming shop and get it fixed for just £50. DIGMAN
