Re: my laptop keyboard is typing different letters and...
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
The layout of keys can differ with different model and make laptops. The keys with letters and numbers on them are used with the Num Lock key, if you press the Num Lock key them keys will type numbers instead of letters. If you press that key again they will type letters as normal.
The keys with icons on them are used with the function (Fn) key. That means that you hold down Fn and and use the F keys to adjust things like brightness, volume, mute and Wireless radio etc.
If you are wanting a full breakdown of your laptop models keyboard then i suggest you download the user manual from HP support website. Link below.
It sounds like you have the num lock switched on, most laptop keyboards are too small to have a separate numeric keypad so use the letter keys on the right side of the keyboard for this. (you should note numbers as well as the expected letters on the face of these keys).
To turn off the num lock, hold down the Fn key and press Ins. (located top right of the keyboard).
Sounds like you have turned on the NUM LOCK on the laptop keyboard. If
you look closely you will see the numbers on those keys (maybe in a
different colour).
You need to turn off NUM LOCK again. On the
laptop I'm looking at, this is done by pressing Fn and END together,
but the key should be marked with NUM LOCK as well.
if you press the L key and the number 3 comes up. you likely have the num lock on.
is different for every computer but usually you can deactivate the num lock by pressing 2 keys at the same time. the fist key is usually the key labeled (Fn) and the other key is usually a function key (the ones with F an a number), the way to find which is the other key is to look at the keyboard and try to find one that has a simble that looks like a tiny numerical key-pad press both keys and a light that signals that the num lock is on should go off. at that point you should have your l and any other letters again typeable.
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk keycombinatioins
You need to press the NUM Lock key.
The NUM lock key is usually the same key as the ScrLk key but to select the NUM lock you need to press and hold down the Shift key and then press the NumLk/ScrLk key. A LED light will light up to indicate the number keypad is on.
You've probably got number lock activated / deactivated. This is especially common if you're using a laptop computer. Look for the "Num Lock" button on your keyboard and try pressing it. If you're using a laptop and the Num Lock button is a different color, you might need to hold another key "Fn", Shift, Cntrl, etc while pressing "Num Lock".
