Question about Sony KP-53S70 53" Rear Projection Television
Sanyo multimedia pro rx
My TV seems to have a Ghosting problem. The TV needs to have its mirrors aligned, but I don't know how so can you help?
My Acer X223W auto-aligns my screen 2
I was having this exact same issue. I held down the 'e' button and let it re-auto config and it seemed to clear up the problem.
May 28, 2012 | Acer X223W Monitor
Hello. I contacted you earlier, your email went to my spam. I missed it and cancelled . Sorry. The problem. I have is a ghosting picture of a program I watched earlier. The problem comes and gos....
Good day!!!
Sorry but I can't see any previous questions from you to my email but anyways lets proceed to your problem..
If you are watching TV shows and the picture is ghosting kindly try to play a DVD movies or anything that having video on your DVD if the picture is fine when you play a DVD movies your TV is in good condition you don't have to worry about..If the picture is fine when you play a DVD let me know and I will give you next step of troubleshooting..
However if you play a DVD but still picture is ghosting there something wrong with your TV..
If you are using DVR then when you back to TV it become ghosting..It is possible that you hit the wrong button on remote..you can also try to restore factory settings to correct all possible wrong set up and also to to auto scan your TV to get back all channels clearly..
Hope it helps..
regards,
chester
Jan 25, 2012 | LG 50PC1DRA 50 in. Plasma Television
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
I can't find any documentation on how to remove the primary mirror for cleaning. I'm a newb and don't want to mess anything up. Thanks, Bob
First -- how do you know the mirror needs cleaning? Did you shine a flaslight down the tube and see some dust? Never use a flashlight to determine if a mirror is dirty-- they are ALL dirty when you use a flashlight to check them.
Only clean the mirror if it is interferring with the views through the scope.
There is a ring around the back-- remove those screws and the mirror should come out-- don't driop it! Then remove the mirror from the mirror cell.
Sep 03, 2011 | Celestron Advanced C10-NGT (600 x 254mm)...
Slight ghosting and color alignment problems
comvergencia that reviews the misaligned with the remote control and traps
Jan 05, 2010 | Televison & Video
Ghost and red
Sounds like the TV needs major convergence alignment and possibly a a full color scale adjustment. Projection TV's have the most alignment issues. Since I don't know manufacturer I can only give you general ideas. Most projection TV's have either auto or manual alignments which can be accesed through the menu. However the adjustments may be tricky to get to. Once convergence is done if video is still red you will need to get in the TV and set up biasing levels on each tube. Hopefully the tubes are just slightly degraded and can be readjusted for a nice quality image.
I suggest finding a local guy and asking him to possibly do a quick a;ignment for a fixed price.
Good luck
Apr 18, 2009 | Televison & Video
GB4308 Ghosting
The cost I don't know, but this can be fixed. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Jan 02, 2009 | Apex Digital GB4308 43" Rear Projection...
THE RED, BLUE, AND YELLOW COLORS SEPERATED ON A 52 IN HDTV. THE PICTURE SEEMS TO HAVE A GHOSTING EFFECT TO IT
Have you used the color convergence settings on your TV?When the settings are off you will get this effect sometimes if the TV was jarred pretty hard it goes out of alignment.There should be a setting on your menu.If that doesn't help it may need re aligned by a repairman.
Aug 10, 2008 | RCA Televison & Video
Samsung sp42w5h ghosting
The convergence ICs are usually the problem there are two of them STK392-040 which need to be replaced and possibly the 4 150 ohm 1watt and a couple of the 3.9 ohm 2 watt resistors this is a fairly easy repair if you can solder. You can get replacement parts at the following link and they provide free instalation instructions with pictures so you can do the repair yourself.
here's the link.
http://servicemanuals.vstore.ca/
Jun 26, 2008 | Televison & Video
Convergence board
YOU WILL NEED PROFESSIONAL HELP THIS IS NOT A DO-IT-YOURSELF JOB. SORRY
Jun 01, 2008 | Mitsubishi WT-42315 42" TV
Sony KP-53S70 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
