Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
Alpine PDX-1.1000 to a 10 "Alpine SWX-1043D
How do i connect an Alpine PDX-1.1000 to a 10 "Alpine SWX-1043D?
Posted by dafattony on
  • Anonymous Mar 17, 2014
    bridge a ALPINE PDX 4.100M
Anonymous
    Problem Solver:
  • 9 Answers
Straight up. Since it has the power saving technology where it gives out the same power at 2 ohm and 4 ohm loads then u dont have to bridge it and since its a single speaker you dont have to bridge it and since it is a mono block oyu dont have to bridge it. just wire + to + and - to -.
Posted on Jun 02, 2009
Alpine type x sub quit playing
Check if the subs have any impedance with a multimeter you should get 4 ohms if you do great you need to check your wiring to and from the amp . If not there toasted they can probably be repaired there are repair services for them check your costs though might be cheaper to replace them.
Apr 08, 2013 | Alpine 2 Swx-1043d Car Audio 10" Type-x...
My amp wont come on and it is hooked up correctly... is it possible for condensation to ruin an amp?
if there is moisture inside of the amp, it can definitely keep it from working. if it remains wet long enough it can cause corrosion of the board and parts.
Mar 22, 2011 | Alpine SWX-1043D Car Subwoofer
No sound
your positive and negative on the back of the sub is backwards.
May 05, 2010 | Alpine SWX-1043D Car Subwoofer
I need to get my alpine swx-1043d subwoofer vioce coils replaced were can i do this at
I would try alpine and/or do a web search for speaker repair or speaker rebuilding. In most cases vc replacement involves replacing the whole cone, vc, spyder, and maby the surround. Bassically all the moving parts in most speakers are glued toghther with high-temp epoxy glue.
If it's a type-x it's worth rebuilding. My guess is around $100
There are a few places out there that can hot-rod the rebuild with larger gauge vc wire and thicker lead in wire and other mods that will make sure this doesn't happen again. Do a thorough webb search. The more competant people out there do repairs and also custom build their own subs.
Apr 02, 2010 | Alpine SWX-1043D Car Subwoofer
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My subwoofer stops when volume is increased
have u check the radio out do u have an eq
May 19, 2008 | Kicker CVR12 Car Subwoofer
PDX 4.100 In Protect Mode..
According to the manual, the issue could be:
  • Internal issue with the amp circuitry.
  • A short on the speaker output(s).
  • Power source voltage is too high (aka above 14.5V).
  • Overheating.
The easiest thing to do is to try removing the connections to the speakers at the amp and see if the issue disappears after each set has been disconnected. Keep removing wires until both LEDs stay blue.
Mar 15, 2008 | Alpine PDX-4.100 Car Audio Amplifier
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
431 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
