My Peugeot 206 1.9 diesel 2002 is stuck in economy mode how do I get it out of economy mode I have done the reset procedure but still has not got rid of the problem
SOURCE: peugeot 307 hdi 2002 5 door will not start
Check the fob battery because if the battery has gone then you can't immobilise the car immobiliser which in turn doesn't let you start the engine however it cranking. open the bonnet and remove the clips of car battery for a good 15-20 minutes and put them back and check your remote key and try to start your car. If nothing happens then let your car diagnosed by a experienced mechanic who is able to read out the ecu codes.
SOURCE: peugeot 206 cc fan belt change
hi ive a peugeot 206cc 02 reg, the STOP light keeps flashing ive checked the normal oil and water but alls ok so whats the problem still runs fine and temp stays where it should??? any tips??
SOURCE: peugeot 206 glowplugs
If your not good at mechanicing I suggest you take the car to someone that is experenced.
The reason I say this that we have loads of cars into the workshop with glowpugs broken in the head of the engine with the result of us having to remove the cylinder head.
What happens is that the tip of the glowplug breaks in the head when being removed if it is not done properly.
There is a way that we have found that they can be removed easily without breaking them.
Firsty run the car engine until warm, then we pour a little Diesel fuel onto each plug & let them sit for 15mins or so.
Then we remove them with a deep socket 1/4" drive so we don't put to much pressure on them.
they should screw out easily but we turn them out 1 whole turn then back a 1/4 add a little more diesel ( thimble full) & gently screw them out.
If they start to get really tight screw in again a little then screw out again.
The nuts that hold on the wires just need to be nipped up with a small 8mm spanner, but do not over tighten.
SOURCE: Peugeot 307 diesel 307 - Unblock diesel filter
if it says the diesel filter, then that is what it means,a fuel filter.normal service requirement on any vehicle and can be done for small dollars at any garage
