Question about NetGear Computers & Internet
Connect 192 168 0 1
My password
Posted by zia moussavi on
Chris Hingee
  • NetGear Master
  • 32,281 Answers
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash.
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password
You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Posted on May 19, 2013
My Kobo Arc 32, asked for a password, when I tried to try the WiFi. I don't remember setting a password. So, now it's asking for an guest password.
It is not the Kobo that has set the password, rather the router for the wifi that you are trying to connect to. You just need to know the password for the router to let you connect. If a router has no wifi password, it is considered unsecured and ANYONE can access it. So most all routers use password protection. If it is YOUR wifi system, and you no longer know the password, you can change it if you access the router setup for wireless and change the password. Be advised, however, that all devices that connect to the wifi will need to change their passwords as well or not be connected. If it is not your wifi you are trying to connect to, then you need to obtain the wifi password from that wifi system's administrator.
Nov 06, 2015 | Tablets & eReaders
Connecting a genbook to wifi
Turn on your computer and locate the Wi-Fi icon.
This is located in the system tray in the bottom-right corner of the screen.
The icon looks like a series of rectangles that increase in size from left to right.
Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks.
Choose a Wi-Fi network you want to connect to and select "Connect."
Enter the password into the password text box if a password is required. If a password is not required, you will automatically connect to the Wi-Fi network.
Click "OK."
Oct 11, 2012 | Computers & Internet
Password to connect
you will have to contact the person who configured the router, they will have the encryption password. If it is your device and you forgot the password you will need to connect through the devices web interface and reset the password. If you forgot the admin password to the access point your only option is to factory reset the device and reconfigure it.
May 03, 2012 | Trendnet TEW655BR3G 150Mbps Mobile...
I need to change my password on my speedtouch dialup connection
To Manually change the dial up password in Windows 2000 or Windows XP -
Go to your Start, Programs or All Programs, Accessories, Communications, Network and Dial-Up Connections
- Select your connection
- Enter your new password exactly as it was given to you in the password box
- Be sure the Save Password box is checked
- Click Dial to connect to connection with your new password
- Your new password will be saved when you successfully connect to connection
- Be sure to save your new password in a secure location
Dec 07, 2011 | Microsoft Windows XP Home Edition English...
I need to change my password on speedtouch dialup connection
To Manually change the dial up password in Windows 2000 or Windows XP - Go to your Start, Programs or All Programs, Accessories, Communications, Network and Dial-Up Connections
- Select your speed-touch connection
- Click Dial to connect to speed-touch with your new password
- Your new password will be saved when you successfully connect to speed-touch
Forgotten password to connect to network
In order to check or change your password for NetGear , go to http://192.168.1.1. It will ask you for a user name and password. The default is “admin” and “password”, Once you are connected, go to Wireless Settings and you have the option to change password there.
Hope this helps
Apr 28, 2010 | NetGear DG834G Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
Have a d-link router with password. Ipod touch(8G) won't connect
Try remove the password on D-Link router, put it on open conditions (no security enabled).It should work.
If still won't connect, try using laptop or any wireless device to connect to router(without password), if connect, then there's something wrong with your Ipod.
Dec 08, 2009 | NetGear DG834G Router
Random wrong passwords
Any router that your connecting to wireless, without a password, does not have wireless security set up on the router.
Any other wireless router that you are trying to connect to that does not allow you to connect wireless, has wireless security set up and that same security must be set up on the wireless device (like laptop or desktop, whatever is not connected via ethernet cable.).
Reply back what you find and I will be glad to help more.
Feb 04, 2009 | Adaptec Computers & Internet
New dial up connection with the “Save Password” option enabled
After setting up the MobilePro 900 for the first time (or after a hard reset), a soft reset is required to correctly save the dial-up networking passwords for remote networking. If your MobilePro 900 is already configured with a RAS connection that will not authenticate, you can do the following to fix the issue: * 1. Use the stylus to depress the reset button located on the bottom of your MobilePro 900 and allow it to reboot. * 2. Tap Start a Programs a Communications a Remote Networking. * 3. Open the dial-up connection by double-tapping the icon, just as if you were going to connect. Ensure the user name is correct and re-type your password making sure there the “Save password” option is checked. * 4. Tap the “Connect” button to save your password. If you do not tap the connect button, the password will not be saved correctly.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Open Questions:
Netgear Router Customer Service Phone #@[+1-844-33O-233O]@ Number USA Netgear Router Customer Support +1-844-33O-233O for Netgear Router Customer Service Phone Number via Helpline Toll Free Number Netgear Router is known for offering different astounding administrations including ...Netgear Router has ranked the list of reliable and widely used among all other Antiviruss. As being the technical equipment these Antiviruss are vulnerable to failure. But no matter which model of you are using Netgear Router customer support number will provide assistance and guidance for every issue confronted by you in any model of this . We Tech are remote Netgear Router support service provider for Password recovery phone.Look Tech at your Technical for Repair , for customer phone number labeled as Customer Serial phone Number,to repair Serial No, technical. Netgear Router created and circulated by Netgear Router Technologies, provides malware obstacle and removal throughout a subscription phase. It uses unique signatures and heuristics to recognize viruses. Additional features comprise e-mails spam filtering and phishing safeguard.support It proficiently takes care of all types of malwares, together with all computer viruses, computer worms, computer viruses, adware, Netgear Router Tech Support And Help Center Contact Phone Number Trojan horses, and spywares etc. Netgear Router at one point covered 50% of the US marketplace and still it is known to be one of the most trusted all across the world. Malwares are the most hazardous bugs for the computing world.
Dec 03, 2019 | NetGear Computers & Internet
Computers & Internet Logo
216 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
