Question about Garden
Honda Harmony II HRR216 won't start
I've had someone's Honda Harmony II HRR216 sitting in my shed for 3 years and I recently got it out to see if I could get it working. I drained and replaced the gas and oil, the spark plug and air filter are both new, but the mower still will not start. Any and all advice welcome!
Posted by jeff berryman on
  • Garden Master
  • 18,438 Answers
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
Posted on May 19, 2013
5 Related Answers
Chuck Bamforth
  • 205 Answers
SOURCE: yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Posted on Apr 24, 2009
Anonymous
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
Anonymous
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
eugbug
EugenesDIYDen
  • 479 Answers
SOURCE: I have a MTD push mower that won't start every
Have a look at these tips for troubleshooting starting problems with lawnmowers:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
Hope this helps!
Posted on May 14, 2011
Michael Spreafico
  • 407 Answers
SOURCE: I have a troybilt mower with a honda 160 engine
You may have to replace the carb.But before you do.Check the the fuel line.There is a small screen in the carb,it may be clogged.Inside the tank is a small cylindrical filter,make sure it is good.Break the fuel line at the in line filter,to make sure gas is getting to there,if it is the problem is in the carb.
Posted on May 20, 2011
How to adjust the Governor on Honda Engine
Automatic governor. Replace or rebuild carb. Ensure float is functioning properly..
May 30, 2014 | Honda Genuine oem harmony ii hrr216...
I've recently purchased an 88 ford bronco with a 5.0 that had been sitting in a repo yard for about a year. after replacing a fuel pump and filter i was able to get it running. it idles well and s
The first thing I would check is the park brakes coming fully off when released. If the units are rusted and stiff you will have dragging brakes which will give the symptoms you describe. After all it has been sitting for a year with the park brake on.
Apr 04, 2013 | 1988 Ford Bronco
Lawn mower won't start
Take Breather element off,and try to start it Then or if it starts that way cut it off and replace the breather and if it doesn't start You May need to change spark plug also, As if You have flooded it, Gasoline will kill a spark plug
Mar 27, 2013 | Garden
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
May 29, 2017 | 1998 Honda Accord
The Longitech (Harmony One) won't do anything, even the Help button won't work
Check the remote control for its infrared emission. Just get into this blog site for details
electronicshelponline(.)blogspot(.)com
Type this blog address to the address bar of your browser, without any quotes. Press enter, and look the blog named Electro-Help.
I've given a detailed description there about how to check a remote, and how to clean it and repair it.
Apr 11, 2012 | Televison & Video
Garden Logo
1,112 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
