SOURCE: Whirlpool front loader staining..
i have the same washer and i am some times perplexed about stain that appear after washing> i always blamed colors tranfer from other items .I'll keep a closer eye and see if i can find any more. does your washer have any oders that bother you mine does. for the price i feel cheated
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
SOURCE: LG wm-2277hw
If yours is the same problem, water in the dispenser, then the answer is the same...
The reason there is still water in the dispenser, and this in normal by the way, is the unit uses the pre wash and main wash valve to activate the fabric softener. Basically when the two valves come on they force water into the fabric softener compartment. There can be some overflow and it ends up in the blue cup nothing to worry about. Now if you have detergent there, then that is a problem..
Sgt 48
SOURCE: LE ERROR CODE ON LG WM-2277HW
Don't call service, they will rip you off!
See posted titled "LG Tromm WM2277HW will not spin"
SOURCE: Problems with LG WM-2277HW Front Load Washer
It is a rare problem but I've seen it happen. The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser. The dispenser can be disassembled by unsnapping the top section where the hoses are connected. Once the top section is lifted, you can safely pull the drawer out. Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer. Recommend replacing the dispenser to resolve this problem.
