I have an fujitsu siemans amilio d8830 and i cant turn it on i plug in power lead the lights on on the transformer i press the start button and nothing it wont even light the lights on the key board ? can u help please
Question edited for proper spelling of maker name and better English.
Question moved to Fujitsu category.
No model, service tag details given, so generic help.
Re: E744 - NumLock flashing
Remove the battery and the ac adapter and press the power button again for a view seconds. After that connect the ac adapter first an try again if you can start your device. If you are facing the same problem again you should contact a service partner regarding a repair of your notebook.
May 5, 2015
https://www.fixya.com > ... > Fujitsu > LifeBook
Blink codes are often displayed after a user adds memory to the computer but does not seat the module properly. The LEDs may also blink error codes if a ...
you have a SHORT circuit maybe in the power supply, transform, capacitor, motor or lower board. You must call some tech qualified, for to fix it. see the block diagram. God bless you
Hi, try this take out the power lead from back of xbox, turn power lead off at mains and leave unplugged from mains and xbox for at least 5 min, plug it all back in but make sure you push the power lead into the back of the xbox really hard push it in the try hard to push it in further then plug it into the mains then switch on and press the on button.
if after trying that it still dont work try pressing the open button for the dvd drive as this will switch it on also if their is a problem with the on off button.
if after doing the above you still cant get it on give me a shout back then ill assist you further ok
check out let for power -plug in light it works then u need voltage testor and test plug at printer and compair to settings on transformer if it matches bad printer if it does match bad transformer, bad printer do not repair costs more to fix than getting cheap printer transformer no good then check prices first, maybe till cheaper to buy printer , if outlet doesn't work check main fuses and see if one is tripped if yes reset if not bad outlet or wire, replace outlet $1 to buy if bad wire need and electrician or use extension cord to another outlet
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Tricky one this without looking at it - You may very well have a faulty lead, transformer/voltage regulator,power/plug or switch.
Would need to do hardware tests to determine the fault.
Regards,
Freddie
Firstly please install Service pack 2, there are too any security problems with service pack one and power settings problems, this can be ordered free of charge from Microsoft or downloaded.
When you say it boots up when you plug it in do you mean it comes out of Hibernation and returns to the desktop saying programmes are running or does it do a full boot up.
Sounds as if you need to go into the bios to enable ACPI, see this post on how it's done.
http://www.fixya.com/support/t121839-monitor_turns_off_automatically.
Go into control panel>power options and click advanced tab to make sure the power button at bottom reads 'when i press the power button on my computer' 'SHUTDOWN'
Then on the hibernation untick enable to see if it cures it.
