Question about Amazon Kindle Fire HD
Will not power on - Amazon Kindle Fire HD
Posted by lucy on
Christian A Bryant
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
  • 74 Answers
If you are not able to power the Kindle up, try the following:
1. Plug the Kindle into an alternate charger, if you do not own a second charger go down to Staples or Radio Shack and buy one
2. Plug in the Kindle to the new charger for 12 hours. If the Kindle attempts to power up hold the power button down until the Kindle powers down
3. When the Kindle is done charging, press and hold the power button for 30 seconds, release, waiting 2 seconds, then press and release the power button normally.
4. The Kindle should be powering up
5. If the Kindle is not powering up, contact Amazon for a replacement.
Posted on Jun 09, 2013
How do I reset mu w7 hipstreet tablet?
If your tablet is on, power it off.
Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power). You will see the word Start with an arrow drawn around it.
Press Volume Down twice to designate Recovery mode.
Press Power to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark.
While holding down Power, press Volume Up.
Use the volume keys to scroll to "wipe data/factory reset" and press Power to select it.
Scroll down to "Yes - erase all user data" and press Power to select it. found it here
http://www.askmefast.com/How_to_reset_the_password_on_hipstreet_tablet-qna3158749.html
Jul 07, 2015 | Tablets & eReaders
Steps to reset tablet which is stalling up again
hard reset in android tablet PC's
different keys have hard reset in android tablet PC's
u can try like this method
  • volume down + home button + power button
  • volume down + power button
  • volume up + menu + power button
  • volume up + power button
  • volume up + cam +power
  • volume up + lock button + power
Hope this helps !
Dec 19, 2014 | Tablets & eReaders
Grandson used pass word and forgot password, now I can't unlock tablet.
Try resetting it by holding down the power button for 10 seconds.that would shut it down. Restart then try logging in. Try to factory reset using the combination buttons as listed below
look for a tiny reset pinhole along the case it may reset the tablet too All RESETTING Ways Below Holding Down Certain Sequence of Keys or Buttons will put Most Tablets or Android Phones in Service mode to Factory Restore to New.
Hold Vol + & Power 20 sec
Hold Vol - & Power 20 sec
Hold Vol + - & Power 20 sec
Hold Home & Power 20 Sec
Hold Vol + & home & Power 20 sec
Hold vol - & home & power 20 sec
Hold Vol + - & Home & Power 20
Dec 12, 2014 | Tablets & eReaders
Asus 1025c won't get any power
did you try another power adapter? If it's not the problem of the power adapter, you might need to check again the power jack, Asus uses a very small power jack for EEE PC series, it is easy to loose on the motherboard..
If a power jack needed, check this page: http://www.lapdiy.com/asus-eeepc-eee-pc-1025c-netbook-dc-power-jack-socket-p-42259.html
wish this can help you.
Jan 16, 2014 | ASUS 1025C-MU17-BK Eee PC Flare 1025C...
Sony tablet
Option 1 (Non-destructive)
  • Press and hold the power until it powers off. This is considered a "hard reset"
  • Power the device back on.
Option 2 (Destructive)
  • Typically involves powering off the tablet. Once off tap the power button then press and hold Power + Vol Down until you get a menu
  • Us the volume buttons to navigate to "factory reset"
  • Use the power button to select it.
  • This will wipe out the tablet and reset it back to defaults.
Apr 23, 2013 | Tablets & eReaders
Mid tablet wont shut down
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
Jan 30, 2013 | mid Archos M729B Android Tablet
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
Amazon Kindle Fire HD Logo
94 people viewed this question
Top Amazon Tablets & eReaders Experts
Ron Rak
Ron Rak
Marvin
Marvin
Jean Thiebaux
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
