Hp omni 100 3 g ram 500 g hd will no longer boot into windows 7 i have tried the restore feature and the factory restore settings in the recovery program but not that feature is now greyed out and is no longer a option l have tried the following i ran chkdsk /f no problems found ran the boot rec /fix boot command nothing helped there is there a way to force the computer to brin g up the factory restore feature in the dos command and if so how to do it
A desk top PC?, what is it? use full names of things.
you never said what the screed did, is it black all the time.
if yes, does BIOS screens work?
F11 key, (the magic key) on older HP its F10 older still (none)
what year PC is this, full model number , type it out full off the service tag.... i cant guess omni this is. there are 29 models and subs.
The newer HP systems, all have this F11 key
this is the magic key as you boot, you hit it fast (tap tap tap)
and it goes in to recover mode. My 2006 Laptop does.
the HDD if still working and corrupted,
will run the virtual installer disk, via a hidden partition on said HDD>
if that is confusing, try to imagine 3 ways to install.
F11
HP recover disk called the media kit. (uses on replace HDD )
MS disks, wrong, and will fail., ask how if must,,,,
if you and gone to HP forum or the support page
you'd have seen there is may different omin100s, lots
sorry cant guess yours...
you asked for help and cant muster up the service tag words
full model at least.
if you had id have pointed to the page that tells you what to do step by step, at HP.com
even what to do when it dont boot,all ways from SUNDAY.
the oldest one supported is 2010 year.
here is 100-5000 omni ,series, many in series.
https://support.hp.com/us-en/product/hp-omni-100-5000-desktop-pc-series/4273707/troubleshooting
and last
no start actual pages... i see it covers most ways, (weak on hardware causes, there are vast cause under that topic, ask)
https://support.hp.com/us-en/product/hp-omni-100-5000-desktop-pc-series/4273707/document/c01884928
SOURCE: hp pavillion trying to boot from dos mode
my pc is writting Disk boot failure, insert seystem disk and press enter. pls help.
SOURCE: recovery option on boot doesn't work
its prob the partition for recovery has been deleted
or corrupted. u need to use cds now
SOURCE: Error 0x400 100 130000 1002 while restoring factory image HP
I am assuming you are trying to reinstall Vista. Apparently, HP's recovery partition is less than perfect and the recovery disc you created is probably worthless. (and you can NOT make another one, they only let you make one!) You are not the only person to have this issue.
Here are some things you can try:
1) Borrow an OEM version of Vista from someone...anyone. It sounds like you are proficient with PC's and maybe you know someone who works in IT. Use your product key (25 digit key code) and you should be able to reinstall.
2) if you like Vista, buy yourself an OEM version. It will not have all the factory (HP, Dell, Acer, whatever) BS on it. It will positively work because your hardware if fine.
3) Put XP on it. Personally, I think Vista is a mess. Microsoft is working on "OS7" and soon Vista will be like "Millennium".
Sorry it's not an easy fix, but glad your hard drive and memory show no errors.
SOURCE: How to get to recovery partition when booting up HP Pavillion MX
The same problem happened to me today on my hp Pavillion a1600n.
Try pressing the F10 key as the computer is powering on. This may allow the computer to access the recovery partition on the hard disk. If you get that far, then you can restore the user partition from the recovery partition. If it is like the a1600n, then you can do a restore of all the content and either leave your own data files intact, or, have it reformat the user partition and then you WILL have to restore all the data files. In either case, you will likely need to reinstall any applications that were added AFTER you got the PC. (Or, in my case, some apps were still kinda working...).
If F10 does not work, you may be able to create a PC Recovery Tools CD from a different hp XP machine, and boot that CD. During part of that boot up process you may get the opportunity to run the Recovery program.
Hope that helps!
If you have the Windows 7 disc, start up the computer and hit F12 to boot off the DVD. Go into the recovery options, choose "command prompt" at the bottom.
Type "C:" without the exclamation marks and hit enter
Type "dir" and hit enter
Make sure the directories look like your C: drive, there should be the
Users, Windows, Program File folders etc. If it is not right, try D:,
E:, etc.
Once you know you are in the right drive, type "chkdsk /r" and hit
enter. It will do a full check disc which will take about an hour.
After it is done, type "bootrec.exe /fixboot" and hit enter then "bootrec.exe /fixmbr" and hit enter. Reboot and try to boot into safe mode first.
If you don't have the DVD, try to hit F8 and choose "repair your computer", then follow the steps above.
all of this has not worked either
