I can not turn the warming drawer on because the control knob will not turn. I have tried replacing the knob with one from the burners but it still will not turn.
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Hello. The part number you need for the control panel/switch assembly is 74011491. The actual oven control unit is 74011494. The following list shows some(but not all) of the error codes you might encounter. I hope this helps you!
1c1c shorted key
1c2c membrane keyboard disconnected
1c4c board to board communication failure...." "
1c6c EEprom hardware fault..........................." "
1c7c control not calibrated............................... replace main board
1c8c eeprom crc error--user options..............." "
1c81 eeprom crc error--cook profile................." "
4d21 no cooling fan rotation
4d31 cooling fan on when de-energized
4d41 cooling fan overspeed
4d51 door switch circuit fault
In the service manual, there was no "warming drawer" error code listed in the code chart.
You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
sounds like the thermal fuse needs to be replaced on it. unfortunately, it's not resetable. i would have a qualified technician look at it and replace the fuse.
