Deleted channels some of my channels have randomly been deleted ive tried the autoscan manual scan and update but im unable to restore the channels help please
It sounds like you're experiencing an issue with your Hitachi 51F59A TV not allowing you to select or highlight digital channels for autoscan. Here are a few things you can try to resolve the issue:
Check the TV's settings: Make sure the TV is set to the correct input (such as "TV" or "antenna") and that the channel search or autoscan feature is turned on. Consult the TV's manual or the on-screen menu for instructions on how to access these settings.
Check the TV's connection: Make sure the TV is properly connected to a digital antenna or cable box. Also, check that the cables are securely connected and not damaged.
Check for a firmware update: Sometimes a firmware update can resolve issues like this. Check the TV's manual or the manufacturer's website for instructions on how to check for and install firmware updates.
Try a factory reset: If the above steps don't work, you can try performing a factory reset on the TV. This will restore the TV to its original settings and may resolve any issues with the channel search or autoscan feature. Consult the TV's manual or the on-screen menu for instructions on how to perform a factory reset.
Check for a hardware issue: If none of the above solutions work, the issue could be caused by a hardware problem with the TV. In this case, you may need to contact the manufacturer or a repair professional to have the TV serviced.
If your Onkyo tuner model 4301R is not performing an autoscan, it could be due to a variety of issues. Here are a few things you may want to check:
Check the antenna: Make sure that the antenna is properly connected and positioned for optimal reception.
Check the cables: Check the cables connecting the tuner to the antenna and any other audio/video components to ensure that they are secure and not damaged.
Check the settings: Make sure that the tuner is set to autoscan mode. You may also want to try resetting the tuner to its default settings and then perform an autoscan again.
Check for firmware updates: It's possible that there is a problem with the tuner's firmware. Check to see if there are any available updates and install them if necessary.
If you are unable to resolve the problem, I recommend contacting Onkyo or a qualified repair technician for further assistance.
Press the menu button.Go to the scan button.Manually enter in the channel you wish to add.Press the volume or channel button to 'add'it and if you press it again it will show delete(probably volume,many different brands have different ways to do it yet still basically the same).Do the same for all the channels you want.I use delete for channels such as C-span and a couple of other nonsense channels I do not really care to watch.Even if a channel is deleted,you can still watch it by manually entering the channel number on the remote.After you finish,hit menu to exit the setup.
you should not have factory reset when you lose a chnl delete the chnl then rescan you never need to factory reset you lose the flash or newest update you had installed reflash your box and delete the chnls that are scrambled only and then rescan
My set top box has setup menu, channels, autoscan to scan for channels. They changed some of the channels here after the original switch to digital, and a fresh autoscan was needed to again find the channels that moved. See if your box has autoscan for channels, and do it.
Just updated using below, have got all back
have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels
have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
