GPX D1816 DVD Player Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DVD Player D1816 shows Wrong Regional Disc message
I bought a D1816 player in the US. I installed it in India and when I use a DVD disc bought hee it displays Wrong Regional Disc message. How to solve this problem
Can I play VCD movies on this player?
Can I play audio CDs on this player?
Nanny
Level 3:
Genius:
  • GPX Master 2,351 Answers
  • Posted on Aug 29, 2019
Nanny
GPX Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989158
Points
7262
You may find an exclusive way to hack your DVD player and make it region free, chances are there is not your DVD player model on the website, or your DVD player is not hackable at all. You can use a region free DVD player program to play your region-locked DVD discs on your computer. You can try Leawo Blu-ray Player. Leawo Blu-ray Player is the very program you can use to bypass the DVD region code of a disc.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2051
Points
7
Many DVD players are preset to one region and if you use a DVD destined for any other region, the player will refuse to play. Some players have the option to change this to universal mode. Check your player's manual if yours has this facility.
Yes. You can play VCD movies and and Audio CDs on most players.
What does the message Wrong Regional Disc mean
Almost all commercial DVDs that are sold have region code, which only allows the DVD to be played on DVD players that have this region code, and the only DVD players that typically do have this region code are those sold in that same region.
3helpful
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
Keeps saying wrong disk
The reason it is showing wrong disc is because the laser/lensisnot reading the disc.
The reason the laser/lens is not reading the disc is because it is either weak or dirty.
To fix it if it is dirty, try to clean it with a lens cleaner.
If it does not work, then it means the lens is weak, and to fix the lens you have to replace it with a new compatible lens.
Get the appropriate screwdriver, open up the cover, unscrew the disc tray and try to locate the lens and replace it with the new one.
test with a DVD disc.
Take care
1helpful
My dvd player keeps saying wrong disc on everything I put in?
you need to know the CD format if it is supported by your DVD if not buy the match one or it could be scratch CD.good luck
2answers
Dvd in player but display says no disk
Check the regional code of the DVD you want to play. It is at the back of the DVD cover. It should be compatible with the regional code which your DVD player can play. If they are not tallying the disc will not be read
3answers
Wrong regional disc
Hello mperona,
The reason you are receiving this message is due to the region settings on your dvd player. Dvd players use region settings to allow them to only play dvd's from certain parts of the world. Your dvd player's region settings do not match the region code of the dvd disc.
The only way is to make your dvd player multi region....you will need to post the make and model of your dvd player so I can search for a solution that will work.
Thank you for choosing Fixya!
2answers
Kenwood DVD player 5 speaker system
There is nothing wrong with it, it is set to only play in the region it was purchased from. That is how all DVD players are made, with regional settings. No repair is going to help, you just need a DVD player from the proper region to play those disc's.
2answers
2answers
Nexxtech N600 D wrong regional code
I have nexxt tech dvd 161-1000, I have the same prblem " Wrong Disc", I cleaned the lense, still same...Pls advice
Top GPX Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
