Question about Directv HR10-250 DTV Receiver
Multiple TV wiring to one D-TV receiver
What components are needed and wiring diagram
How to connect my lg lcd tv to yamaha rx-v850
Use the Component Out sockets (RCA sockets - Yellow , Green , Red yes 3 wires) on TV to Component In sockets on Receiver which is again 3 wires
Jun 14, 2015 | Yamaha Rx-v850 Audio Video Receiver Black...
Need to connect multiple components, such as xbox, wii, direct tv, bose, vcr. not enough plug in tv can you pigg back them? looking for a printable diagram?
you can go to walmart or Meijer they should have a video selector you can buy you can hook up about 4 componts to and you just push a button or a switch to the the component you want to use just run your red yellow white cord from tv to it and your games to the selector usually the the cable isle at the store
Oct 31, 2013 | LG 47LE5400 47 in. TV
Seat , mirror, pedals all are not working.
Check all fuses, if none have blown it may be fusible links. Fusible links are like fuses except for they tie multiple components together. They are wires that are designed to fail during a over load to protect the rest of the wires in the circuit. Signs of failure are multiple component failures at one time. You will need a wire diagram to locate them.
May 12, 2010 | 2004 Lincoln LS
I need help putting my surround sound to my tv .dvd and x box
2 ways to do this
if your tv has multiple inputs and an audio output its easy if not there is a way but its more complicated
if your dvd and xbox have HDMI (link to inexpensive hdmi cables) outputs pick up some cables on ebay and use that to go directly to the TV then use the audio output of the Tv and run it to any input on your receiver EXCEPT PHONO. I use video 1 since its easy to remember.
all you do is set your receiver to video 1 and then set your tv to the input you want to watch ie: video 1 for xbox, video 2 for the dvd
this will also work if you use component inputs on your tv (the red, green blue ones)
Now the harder way to do it.
Your receiver has high def (red, blue, green) component inputs
plug your dvd, xbox and cable box if you have one into the 3 video inputs on your receiver and teh TV audio can be plugged into the CD or aux input.
here is the issue.
running both the audio and VIDEO signal through the receiver may degrade your video quality based on the type of video processor that your receiver has.
secondly lets say your dvd doesn't have component outputs and you have to run s-video cable instead then you have to run multiple monitor outputs to your tv as the receiver wil not "upconvert or downconvert" the signal from one format to the other.
Newer higher end receivers will do the conversion but usually not until you get into the $500 and up price point.
when i do installs I try to ,ake it so that people have to push the fewest amount of buttons. Most people know how to switch the input on the TV but then get confused if they have to also start switching inputs on secondary devices such as receivers
hope that helps
Feb 19, 2010 | Yamaha RX-V461 AV Receiver
Looking for a diagram on how to hook up my dish network box to my STR-de597
There is a wiring diagram PDF posted on Sony's support site. However it lacks a configuration for a satellite receiver. Without knowing your particular Dish setup, I'd say use the Component video cables and a fiber optic for the audio if you can. Otherwise, the component video and coaxial cables are your next best choice to get decent video and surround capability.
In both cases, you need 2 sets of video cables One for the in and another for the out. You only need 1 fiber optic or coaxial for audio if you do not plan on running the TV speaker system. Use the video 2 inputs for either video type.
Oct 27, 2009 | Sony STR-DE597 Receiver
Wiring diagram
hi i have a bose home system. it has a 5 pin L shaped rca plug that goes into the bose receiver. that wires got rip out of. i wanted a diagram of the plug to know which wires went where so i could repair it..
Jun 16, 2008 | Audio Players & Recorders
Component Video
Make sure that your source units (DVD, Cable/Satellite, etc) are ALSO plugged into the reciever using Component (you cant have multiple types like S-Video, Composite and Component mixed and matched). Also make sure your TV is on the appropriate input.
Sep 14, 2007 | Sony STR-DE597 Receiver
Directv HR10-250 DTV Receiver Logo
454 people viewed this question
Top Directv Televison & Video Experts
Don Eagan
ray gallant
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
