Question about Kenwood CT 401 Hi-Fi Stereo Dual Cassette Deck Single Dual Cassette Deck
Kenwood hi fi protect
Protect keeps coming on when i press it on meaning i cant use hifi how do i stop this happening
1 Related Answer
alex
  • 4 Answers
SOURCE: Kenwood UD-551M hi-fi stereo ...problem
is there a loose line
Posted on Nov 28, 2012
Audio output to hi fi from d530 sff
Yes there is. You can use the same connector you use for headphones / speakers. You need a cable - type depends on your HiFi inputs could you specify what HiFi you have?
Although Jack-2xCinch (Male-Male) should work on standard HiFi towers.
Dec 31, 2011 | HP Computers & Internet
Need the 4 digit code for a kenwood vr-405 reciever with my kenwood rc-ro509 remote..stop working?
Here are some remote codes for Kenwood Receivers.
The codes are as follows: One of them should work
0027, 0077, 0313, 0186, 0314, 0356
Here is a link to a web site that has universal codes for remotes.
http://www.hifi-remote.com/ofa/codes-amp.shtml#amp
Hope this helps,
Best Regards,
Mark
Jan 27, 2011 | Kenwood VR-405 Receiver
Need the service manual for kenwood hifi set : A522L
The truth is that the service manual for your Kenwood Hi fi set is not available anywhere online. The manufacturers (Kenwood) of this unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer (Kenwood) of this unit via phone or e-mail and request for the service manual from them. They might give it to you or direct you to a dealer where you can get the service manual.
This is the best you can do to get the service manual you are requesting for.
Go to the Kenwood's website, check "Contact Us" and you would see their e-mail and phone number.
Good luck.
Jan 03, 2011 | Audio Players & Recorders
I've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Feb 10, 2010 | Sony Electronics - Others
When ever i turn on my engine which means my kenwood kdc237 shud come on its just flashing protect protect protect no matter wot i press nothig happens need help cant do without music.
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Jan 20, 2010 | Kenwood KDC237SA CD Player
Same problem protect keeps flashing
kenwood has an internal protection feature that stops the output of the speaker channels if there is a shorted wire or bad speaker. this happens for many reasons and is not always serious problem. you can reset the unit by pushing the reset button with the tip of a pin while the until is on. it is a very small black circle located somewhere on the front of the faceplate. it should go back to normal operation after rebooting. if the protect comes back, you need to take it to your nearst shop to have them troubleshoot your speakers and connection.
hope this helps
Sep 15, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Stand by light just keeps on flashing red and i cant press any otehr buttons it just keeps flashing red
something inside the unit has caused it to go on protect mode it sounds. check the v supply from the fan as well as the audio output ic and main pc board.
Jul 05, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Kenwood XD V757 System Protected
check the speaker wires are not shorting out
Dec 11, 2008 | Audio Players & Recorders
Kenwood stereo synthesizer tuner t-85l
T-85L is a component of a hifi system not suposed to work alone. You have to connect it to another Kenwood component (an amplifier like the A85 ) through a special cable to power it on/off. The special cable can be used point to point or as daisy-chained.
Nov 05, 2008 | Yamaha HTR-5830 Receiver
power problem of power amplifier .
if you can open the cover we can give try to solve this problem.
nuwan
Sep 02, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Top Kenwood Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
Kardoc
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
