Hello,can anybody help.....
I have a Brother pr600.When i use the biggest hoop for big designs,it stitches the design but then shunts over about 5mm.This happens on the edges of the design.The mechanic i bought it from couldn't help.It does this on jackets,coats,sweatshirts.
You can try to calibrate the hoops by having the machine turned off and the largest hoop and smallest hoop ready hold down the start/stop button and the needle theader button and turn the machine on while holding those in, you should get a different screen that say a/d test in the upper left corner, put the largest hoop on the machine being shure the screws are tight and hit the l button on the upper right side the numbers next to the button will change, then put the smallest hoop on and hit the ss button once the thats done turn off the machine and on again and it will start normally and try your designs again if that doesnt work take it to a brother service center/ dealer and tell them to check your x-axis position
shunts?
