Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
C48l2p104 wiring diagram
Motor does not run only make nosi
Knocking noise when machine running
see the video and fix it. This happen because the lack of maintenance according to the schedule. God bless you
Apr 03, 2013 | Proform Crosswalk 395 Treadmill
Air unit fan not turning and its blowing hot air . the motor is running and making a humming nosie.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 13, 2011 | Heating & Cooling
Making a nosie on driver side but when i distconte
is it a very fast wizzing noise?
if so the seloniod on the starter motor has gone! give it a tap with a hammer if you can get to it or put the car in 2nd gear and take the hand brake off, make sure the keys are not in the ignition and push the car forward it until you feel the engine turn, it wont start but should free off the starter motor.
Jan 15, 2010 | 1999 Dodge Durango
Frigidaire made a nosie then followed a smell. Took it apart belt is fine.. What is wrong with this dryer
Sounds to me like your motor is bad.
They will make a bad noise and then go up in smoke when the bearings go out and the windings short out...I would check for power to the motor and if there is power going to the motor and the motor does not run then you have confirmed what I think the problem is.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Load knocking nosie from engine.leaking coolent.lost of power. but still runs.
you have "blown" your motor. it sounds lik you have dropped a piston rod and you may have screwed the head gasket as well. either way it is cheaper to buy a motor from a wrecking yard and have it replaced.
Dec 16, 2009 | 1998 Honda Passport
I have a knocking nosie on the right side of the car
front wheel drive ? check your CV joints on the right side , drive axles
Nov 02, 2009 | 1999 Ford Taurus
I can feel heat in the dryer and it makes a buzzing nosie but wont turn when i press start
Turn your power off, then reach inside the drum and turn the drum 1/4-1/2 turn. Turn your power back on and try pressing the start switch again.
Sometimes motors get a dead spot in them and this helps to move it from the dead spot.
If that doesn't help then listen again closely, and may be the humming is your motor running...if the motor is running then that would indicate a broken belt might be your problem.
If none of the above is your problem then your problem could be your motor.
I hope this helps
Oct 01, 2009 | Dryers
Truck wont start makes cliking nosie
sounds like your starter is bad, you could take it off and to the auto parts store and they can test it. My chevy did the same thing, all it is is a bad solenoid most times, which is located on the starter
Feb 22, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Maytag performa dryer
You may have a bad motor that turns the drum. Have it checked out. Does your breaker trip when it stops running? Last I would check is the timer of the dryer.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
56 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
