Question about D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n
Dlinkap How do I disable the password
Posted by Michael Vedder on
max carson
  • 7,627 Answers
You can do a reset to default settings. OR using the on-line setup, change/remove Security Key, refer to the User Manual here: http://www.dlink.com/-/media/Consumer_Products/DAP/DAP%201522/Manual/DAP%201522_Manual_EN_US.pdf
Posted on May 16, 2013
Dlinkap
http://support.dlink.com/emulators/wbr2310/lan.htm
Aug 06, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
I have written (admin) in "dlinkap/" but there is written the password is error? could you explain what is the problem?
Hi There
If you have not changed teh username and password, the username should be : admin and the password should be admin or just left blank.
If the username and passhave been changed, you can reset your router to the original factory settings by pressing the reset button at the back of the router and holding it in for about 10 seconds. you might have to use a thin object to get into the little hole where the reset button resides. Once reset, the username and password as above will work.
Aug 27, 2011 | D-Link AirPlus G DWL-G710 Wireless Range...
I cant get into config my dap1360 by typein in the dlinkap or 192.168.0.50
just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password : <blank>
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Mar 24, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
I cannot have access to the setup page when typind dlinkap on my browser.
you need to type the default URL in the browser. it is ::: 192.168.0.1
and then enter the user id and password.
Oct 31, 2010 | D-Link DAP1360 IEEE 80211n (draft)...
When i write hhtp://dlinkap on the explorer internet i have nothing
Hi i believe that you do have dlink access point device...
if the http://dlinkap doesn't work, try to asign STATIC IP to your computer
assign the following:
IP address:192.168.0.55
Subnet mask: 255.255.255.0
Default gateway: 192.168.0.50
the try to access again the http://dlinkap or simply typein 192.168.0.50
and thats it you're now in the login page of the access point device.
hope this will help
Aug 04, 2010 | Computers & Internet
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Configuration dap 1150
You cannot configure the DLink by the URL address http://dlinkap?
You connect a LAN cable from your computer to the DLink.
Then open Internet Explorer and enter the URL http://192.168.0.1
the default login = admin
the PW is blank (just press Enter)
You can now configure the DLink.
Sep 28, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Setup range extender
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point (DAP-1522/B) Pre-802.11n Logo
276 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
