Question about Maytag Atlantis MDE6400AY Electric Dryer
Replace blower belt - Maytag Atlantis MDE6400AY Electric Dryer
Posted by Ivan Montalvo on
Sal De
  • Maytag Master
  • 2,699 Answers
Unplug it,open the door,remove the two phillips screws that hold the door on and remove the other two on the other side,remove the door and pull the front panel off,just tilt the top of panel out,remove the four 5/16 inch screws that hold the front bulkhead on,then remove the top screws and the L bracket on top,remove the front bulkhead,pop off the metal wire holder on the right side and stick the bulkhead on the right side of the machine so you can remove the drum,lift the top panel up a few inches and slide out the drum,you'll see the mark on the drum from the old belt,put the belt on the drum ribs down against the drum,slide the drum back in,grab the belt,put it under the belt pulley,pull the pulley over to the motor and connect the belt on the motor shaft,put the dryer back together the same way you took it apart,you'll notice two short screws,they go into the holes that have a space around the hole,one goes in the bottom and then the other opposite side up top.hope this helps.
http://www.youtube.com/watch?v=1eeJvqhHEYY
Posted on May 17, 2013
How to replace blower belt on whirlpool cabrio dryer model wed7800xw0
first put pulley onto blower fan housing i think you have to counter clock turn to put the pulley by hand. put you one hand inside the blower housing and hold the fan then use pliers and tight the pulley. now put belt on motor pulley first then put belt on blower's pulley it is hart to put on so little belt on pulley and use other hand and turn fan from inside so blower's pulley turn and belt get to pulley. last tight the pulley again. turn fan by hand to make sure belt run ok. hope it will help you.
Dec 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Instructions how to change blower belt on a *.5 Poulan snow blower
remove the cover behind the engine then remove the top bolts that split the tractor half from the auger side tip the top apart
Apr 05, 2012 | Garden
Honda pilot 2007 blower fan making noise blower fan was replaced once still making noise
Either its developed the same fault or the fan motor bearing has failed, needs greasing or, if there's a belt, the belt is slipping.
Feb 22, 2012 | 2008 Honda Pilot
REPLACED THE BELT AND 5 MINUTES INTO THE SNOWBLOWING THE BELT SHREDDED AGAIN
Check wheels for the belt there is a place or a faulty strap forces were too high.
Mar 06, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Does the GE harmony dryer have a blower motor that is driven by a belt?
No normally the blower is not driven by a belt, it is a motor with a blower wheel attached on the end of it...if the blower motor is not working then you will have to replace the blower motor
Oct 10, 2010 | GE Profile Harmony DPGT750EC Electric...
Blower Belt
That is were the belt rides on the shaft. The belt either broke or slipped off. Replace the belt if you can. Sears can help you with that.
Oct 17, 2009 | Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Auger belt on snow blower keeps coming off
if shop just repaired it, go back. Right belt? Tensioned enough?
Jan 28, 2009 | Toro Blowers Rake and Vac - Electric...
Maytag Atlantis MDE6400AY Electric Dryer Logo
43 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
