Your hdd is password protected. You can't unlock the hdd at home. Change hdd, or go to a data recovery center with the hdd, they can unlock it. Or find the original password from the last owner.
If you only had one administrative user account and you've
forgotten the password, the first thing to try is to boot into Safe
Mode. Do this by repeatedly tapping the F8 key as the computer is
starting up. This will get you to the right menu where
you can use your arrow key to select Safe Mode [enter]. The built-in
Administrator account is disabled by default in Vista. However, if no
other administrative accounts exist on the system it may be enabled. If
it is, you will see an icon for Administrator
on the Welcome Screen in Safe Mode. Log in (the password will be a
blank) and then go to Control Panel>User Accounts and change the
password for your own user account to something you will remember.
Doing all this requires a certain level of computer skills.
You know yourself best and whether taking the machine to a competent
local computer tech (not a BigComputerStore/GeekSquad type of place) or a
knowledgeable friend is the better solution
for you.
If you don't see the icon for the Administrator account in Safe Mode, then the built-in Administrator account is still disabled.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
To delete the Acer Aspire Notebook HDD user password, go to http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.php
The link above will show you to enter 3 wrong password and then copy down the 5 or 8 digit code it displays with Disabled message. Purchase the Acer HDD master password from the link above and submit the code and your model and they will email you the bios master password to unlock your Acer HDD in an hour.. They guarantee it to work or your money back and I have used them successfully dozens of times, saving me a ton of time and money.
I use http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.php when I need to unlock an Acer HDD or Acer Bios, they only charge $20 for bios master password and guarantee it.. Repairing laptops I get one or two a month that is locked with bios password or hard drive password.and they have always worked for me.
HDD password is a security tool which prompt for password during boot.
If you forgot the HDD password then it can be disabled in BIOS settings
Incase you can't go into BIOS settings then you need to reseat Jumpers on HDD inside the Tower(On Motherboard, you ned to open it though"
Hope this helps
You might need to disable the hdd password by accessing the set up BIOS... If you're unable to disable it from there, You need to contact the manufacturer's support so they can guide you on how to disable the password.
Do one thing remove the battery of the laptop in the back side of the laptop after the swicth off your laptop then put in after ten sec and restart the laptop hadd password will be access and bios password also disable.
or do when you start the laptop then press the del button up to ten sec you get it bios setting page after that there is give supervior password give enter twices time your password will be disable.
