Question about LG 42PG20 42 in. Plasma HDTV
Orange bars flashing around the screen
Orange bars keep flashing around the screen and the tv will not display the menu etc......
Posted by james grossnickle on
CoppellTVRepair.com
  • LG Master
  • 778 Answers
This is a link for repairing the power supply board of a LG 42PG20, which also contains a link to an article on how to test the board's functionality, which is actually fairly simple:
http://www.coppelltvrepair.com/p/716/lg-42pg20-ua-power-supply-board-repair-service
Posted on Nov 24, 2013
I have a sony tv and on the menu the convergence option does not high light will it become functional after i do a flash focus ? i dont want to make the screen worse and not be able to do convergence
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Mar 23, 2013 | Sony Televison & Video
Screen Clouds
  • Screen looks 3D
BEFORE
AFTER
Feb 10, 2013 | Philips Televison & Video
The picture is offset far to the left, leaving big black bars on each side. my remotes no longer are able to move the screen manually. I tried to unplug the tv for several hours to reset it and it didn't...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 15, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture started flashing like 3-D in the hd ed mode
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Toshiba 57HX81 57" Rear Projection...
Magicolor when it gets to blue the bar stops moving
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 08, 2011 | Hitachi 51UWX20B 51" Rear Projection...
Crt monitor turned orange and the monitor menu keeps popping up
probably its old or try to check the color status in display property in desktop properties
Apr 21, 2010 | SAMTRON 55V 15" CRT Monitor
The red bar is falling from th etopof the screen
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a Sony convergenece repair kit from the link below.
  • Screen looks 3D
93a1209.pngCONVERGENCE SOLUTION
Their kits include a step by step instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
BEFORE
AFTER
93a1209.pngSolution #2 - CRT FLUID FIX
Feb 14, 2010 | Sony KP-65WS510 65" Rear Projection...
Our tv shows the picture with a green and pink outline around the objects its a bit like watching 3d tv without the glasses can you help ty
  • Screen looks 3D
BEFORE
AFTER
Feb 08, 2010 | Sony KP-46WT520 46" Rear Projection...
TXJ2066 Samsung
  • your problem is due to crt getting weak
  • because of that you are getting fuzzy picture.
  • good luck.
Oct 23, 2007 | LG 30FS1D TV
LG 42PG20 42 in. Plasma HDTV Logo
80 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
