1999 Honda VT 750 CD Shadow A.C.E. Deluxe Logo
Anonymous Posted on May 16, 2013
White smoke sometimes at idle at red lights but goes away
Engine runs fine, doesen't seem to smoke once I take off
Ronald Robert
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 18, 2013
Ronald Robert
Contributor
Level 1:
New Friend:
Welcome Back:
Problem Solver:
Answers
5
Questions
6
Helped
3230
Points
5
White smoke either water or Gas not oil its Black or Blue
1 Related Answer
Anonymous
  • 11 Answers
  • Posted on May 16, 2013
SOURCE: white smoke sometimes at red lights, 1999 honda shadow
One of the main causes of white exhaust smoke and coolant loss is a cracked or warped cylinder head, a cracked engine block, or head gasket failure. A cracked head may allow coolant to leak into one or more cylinders. An internal coolant leak can also contaminate the engine oil giving it a frothy, milky appearance.
05 Nissan Altima 4.2l replaced valve cover, gasket, and spark plugs looks fine with no leaks and engine runs fine,now I have lots of white smoke at start up which goes away once engine is warm.
White smoke indicates water going through your engine or condensation in your exhaust. If it is a lot of smoke you probably have a small leak in your head gasket that seals back up as the engine warms and the materials expand. It will get worse as time goes on. If it's just a little smoke that doesn't last long it's probably condensation in your exhaust, especially if it's cold outside. Condensation is caused by the air cooling down in your exhaust after you shut down the engine.
Engines idle goes up and down after warming up and blows blue smoke
If the engine idles for a while then blows blue smoke this is an indication of oil passing the valve stem seals and being burnt in the combustion process. ( When you are at lights and they change and you accelerate away leacing a cloud of blue smoke this is worn valve guides and failed valve stem seals) As for the idle it could be the oxygen sensor is coated with oil and soot and is malfunctioning henace the cpu cannot regulate the fuel setting correctly. Have the valve seals replaced and clean the Oxygen sensor and check for other fault codes
1helpful
Bad intake manifold gasket?
Sounds like a blown head gasket.
2answers
We just purchased a 2002 Ford Escort. Tonight, when starting the car, it ran very rough and then died. We started it again and it ran fine after that. It has happened twice and it has only happened when...
Could be a idle air problem. The injector could be leaking when you shut it off ..Try some injector cleaner see if it gets better..The idle air shouldnt run rough just idle real low or sometimes it will get stuck and idle high....Are you losing any antifreeze..If you are the 2.0 SOHC engine bad about leaking antifreeze into the cylinder and makes the engine run rough until it burns it out..See if you can see the smoke coming out when it happens..White smoke indicates antifreeze,,Black smoke indicates fuel..
Idle is high at start - 1800 rpm. Seems like excessive white smoke from exhaust. Put into reverse and back out of driveway it has a regular shudder (bump bump bump) but not hard metal grinding sound.....
white smoke out of the exhaust would be a sign that it is burning coolant... if it goes away after it warms up, it could just be condensation inside the exhaust pipe. 1800 rpm is a very high idle, maybe have your IAC motor on the throttle body checked... check engine light? if so have the code read at your local auto zone.
My 1994 Camry idling problem.? It's a 1994 Camry V4, 2.2 L. After i changed the head gasket, my car idle became too slow. It seems like it doesn't have the cold engine starting idling anymore, i...
If it runs fine and the idle is the only problem you could try idling it up some with the idle set screw on the throttle body it sounds like it may be a little bit out of time those toyotas have a fine lins on the timing.
2helpful
Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
3helpful
2answers
White smoke from exhaust
Hello;
The white smoke is from coolant entering the combustion chamber(s). Coolant can enter through the water passages sealed bu the head gasket. You have probably blown a head gasket. You should check your coolant level. You may have acracked head if you continue to drive it and overheat. The temp gauge only reads when exposed to coolant, not air. Take out thhe spark plugs and look them over. A white glossy apperance will indicate water in the combustion chamber. You may need to surface the head once you have it removed so that it is flat. Hope this helps.
Thanks;
Rich
RPM Northwest
1991 tercel rough run and smoke from under hood at times
Check for antifreeze leak, make white smoke under hood, and check your antifreeze level
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
