? Error code EF
Print Unable EF
Turn the power off and then back on again.
The supplied power is unstable.
Step
The irregular power supply is
detected
Main PCB failure
Note:
• The irregular power supply detection error (Machine Error EF) occurs when there is a
large fluctuation in the power supply voltage supplied to the machine.
In this case, if the same power supply is used, the same error might occur again even if
the low voltage power supply PCB ASSY is replaced.
This came from the Brother HelpDesk, yes they rang me and it worked. Cover open
Press Clear
"Replace Drum?" (ignore this and quickly...)
Press Start (blank screen, quickly...)
Press Up arrows then switch to down arrow to 00
Press OK
