Computers & Internet Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HDTV as pc monitor-no digital signal
Hello:
My 24'' monitor failed and I purchased a Samsung 23'' HDTV to use as pc monitor.
Although I had digital display on previous monitor, I cannot now get digital signal, only
analog. Also, every reboot changes color to
16 bit rather than 32.
I'm using xp and a DVI cable from pc to monitor.
I'm using same video card (Radeon 9200) that I used with previous monitor but can't get same results.
Any help would be greatly appreciated as I have spent hours tormenting with this.
Thanks
Anonymous
Level 2:
Scholar:
  • Expert 42 Answers
  • Posted on Mar 18, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
42
Questions
0
Helped
13311
Points
147
Try different Resolutions/DPI and Refressh rates the other possibility is settings on the monitor check the manual of the monitor for use with the pc as in resolution etc.
Newer monitors oftem change there own settings to best suit themselves or act differently if forced to use different settings.
The returning to 16bit seems odd though only other suggestion is trying updated video card drivers from the vendors site.
I have a Samsung Curved Monitor C32F391, and I have installed the driver and files from the CD to my W10 PC. The monitor should be displaying, but it still has no signal no matter what I do. Help?
hello Emily
is this a PC, if yes, sadly non stated,
maker and model.
ok w10 we get that, but what PC?
the PC must be internet connected or Plug and Play fails.
so on the PC it has HDMI port, on the main chassis.?
or in Desktop HDMI add in video card.
is this laptop, desktop or tower. or not book , or tablet.
I am clueless what is before your eyes.
sorry.
Does not turn on
Hello
With any monitor, check the following to determine if the issue is MONITOR related or COMPUTER related.
1. Verify the monitor is receiving power - use a known good power outlet and plug it into the monitor
2. Samsung monitors have a light on the power button - are you getting any color light from this? Orange means it is in "stand by" mode and is waiting for the PC to send it a signal. Green means the monitor is getting a signal from the PC and the monitor is on.
3. With the monitor on, press the buttons on the monitor to bring up the OSD (on screen display) that changes the monitor settings. If you have a green light on the power button and press one of these buttons (AUTO works best), this will display the monitor adjustment options on the screen.
If you see the on screen adjustments, your monitor is working and the issue may be with your PC. Move the monitor to another PC and verify the monitor is working correctly.
IF you don't see anything on the screen and the power light is green, the monitor has failed.
This could be the lights that illuminate the screen have failed (something that happened to my Samsung Syncmaster monitors after about 6 years of use) or the screen has stopped functioning. In either case, replacement parts are hard to find and a monitor swap is likely.
1helpful
My monitor flickers erradically.
Flickering erratically is usually a sign that the fluorescent tubes that light up the LCD are failing, or the high voltage power controller that drives the tubes is failing. Although these can be replaced at some cost and a great deal of expense, it is usually not worth it with very nice, new & larger displays selling for less than $ 150 (23" HD wide screen moitors) from even the best brands such as Samsung, Planar, LG and Viewsonic.
1helpful
Cant get hd to work
What is HDCP?
HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display. The format designed by Intel and licensed by Digital Content Protection, LLC using an authentication and key exchange procedure before video and audio is presented. Products compatible with the HDCP scheme such as DVD players, satellite and cable HDTV set-top-boxes, as well as few entertainment PCs requires a secure connection to a compliant display, the process often described as the handshake. Due to the increase in manufacturers employing HDCP in their equipment, it is highly recommended that any HDTV you purchase is compatible. Although most video devices support high-definition video over component output, analog connections are scheduled to phase out in the future or possibly forced to limited resolutions output.
Why is it important to me?
Although manufacturers are still making most products with at least component HD output, new generation of products like HD-DVD and Blu-Ray devices will limit the analog output resolution (Analog defined as Component or RGBHV). The highest resolutions these devices can output (720p/1080i/1080p) will be available on via the digital (DVI or HDMI) connections that employ HDCP encryption. Any new HDTV purchase should have a digital HDCP compatible input.
It is important to note that HDCP is currently not a standard used in PC monitors, and almost none of these displays have Component inputs. Although PC monitors are HDTV capable, HDCP encryption limits this type of use. If you use an HTPC and want to ensure dual use of your new flat panel display, look for HDCP compatibility.
How does it work?
A simple answer is that an HDCP session will result in the exchange of keys between the source and display device. The source device will query the display to make sure that the equipment is HDCP compliant before video is shown. Non-HDCP devices such as PC's and older model DVI products will work with any DVI compliant display, but the HDCP compliant boxes will show an image only on HDCP compliant display.
Other products affected by HDCP are scalers, switchers, and splitters (distribution amps). While these devices do no authentication for key exchange, they must be able to transmit the presence of HDCP if the video is handled (processed) in any way. Due to the two different formats of digital connections, occasional inability for proper communications may result in loss of interoperability. The newer format, HDMI was designed to be backwards compatible with DVI and in most instances, the two signal types are easily adaptable, but older devices may not always work well with in-line devices like scalers or switchers. These problems can sometimes be fixed in "firmware' although that is not always the case. Incompatibility is often displays on-screen as a snowy image or an error message.
Hope this explains it for you.
How do i use it a a PC monitor? i am connecting it and receiving a "not supported mode" display
To hook up your television to your PC, first you need to get the appropriate cable which is the cable you use in connecting your CPU to your monitor, then turn the back of the television and try to connect it to the port that is on the television.
Then turn on the television, and go to the AV mode, select from the different AV channels you have to be able to access the laptop.
That is how to hook up your television to your PC.
Take care
3answers
Samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
1helpful
Is mhy samsung not hdtv?
You must have a digital tuner built in to the tv if you want to scan for Freeview digital channels. If you have digital cable or satellite the decoder box will unscramble the signal and send it to the tv through a scart connection or HDMI cable. Not all tv's have a digital tuner built in but if it is HDTV it can show an increased resolution image if the output from the cable box or dvd player is high definition.
2helpful
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
1helpful
Monitor
Double check the monitor cable, both going to the monitor, and going to the computer. Ensure it's securely connected. If this doesn't change anything, try rebooting your computer. When the power light flashes, it's in sleep mode and doesn't detect either an analog or digital signal - so either your computer has gone into sleep mode (you can awaken it by hitting any key or moving the mouse) or the cable isn't attached securely. Since your computer is brand new, it's unlikely that anything has broken down already. Another thing to check is to make sure that the resolution in your Display Settings is the correct resolution for the monitor - although it's hard to do this if you can't see what you're doing.
Best of luck, hope this helps!
Grand Canyon Tech
Grand Canyon Tech
