Question about Samsung Televison & Video
How to program remote
How do i program my charter cable remote to operate my samsung tv the remote does not have a setup button
Posted by bill knapp on
David Kassin
  • 600 Answers
Is there a menu button?
sometimes the setup is buried under another button so I would call the cable company and ask.
there is a remote code for your model tv that has to be input.
Posted on May 16, 2013
How do I program a charter remote to a rca converter box
Charter 1060BC2 and 1062BC3 - Setup
www.urcsupport.com/html.php?page_id=762
SETUP. The Charter 1060BC2 and 1060BC03 Remote Controls are preprogrammed to operate the cable box (converter) provided by your cable system, an RCA TV, a Toshiba DVD player, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps; otherwise skip this section.
Program the Digital Cable Remote Control
mscharter.custhelp.com/app/.../program-the-digital-cable-remote-control
Dec 10, 2013 - Highlight or write down the codes and device you wish to programbefore moving on to Step 2. On the remote control, press a device key once (i.e., AUX, DVD , AUD, TV or CBL); it will blink once. Then, press and hold SETUP until the selected mode key blinks twice, then release SETUP.
Charter.net Charter Remote Controls - 1060BC2/1060BC3
www.charter.net/.../charter-remote-controls-106...
Charter CommunicationsProgramming Codes: Select the manufacturer of your device from the list. The codes will appear beside the list boxes. Not all manufacturer brands listed may be ...
Charter.net Charter Remote Controls - OCAP-4
Jan 21, 2016 | RCA Televison & Video
Need tv code for model un32eh40031
This should help!
Turn on the TV you are programming.
  1. Press and release the "TV" button on your Universal remote.
  2. Press and hold the "Setup" button on your remote until the button blinks twice.
  3. Type in the 5-digit code using the number buttons. Most likely code for a Samsung TV is 10812
  4. If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
  5. Use the Universal remote to operate your TV (use Power, VOL, etc..)
Dec 14, 2014 | Samsung UN32EH4000 32-inch LED TV
HOW DO I PROGRAM MY AKB73615801 LG BLU-RAY PLAYER CONTROLLER TO MY SAMSUNG TV
I've NEVER been able to get this remote to work with my ProScan PLED2243A-G television. My Charter cable remote finds my TV perfectly, but this remote is useless for controlling the TV.
Feb 01, 2013 | Televison & Video
I NEED THE MANUAL CODE FOR A SANYO RMT-U130 UNIVERSAL REMOTE FOR MY SAMSUNG TV
If you know the setup codes to check with your TV brand,
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you do not know the setup codes, and wish to know more about setup codes and setup proceedings to many brand remote controls, check this site. General setup codes to check with Samsung brand TVs are : 0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Jan 23, 2013 | Samsung Televison & Video
How do you Program Codes in a Samsung Remote Control TM59 AA64-50236 KIE #1-4 for a Sharp TV
Direct Code Entry
Nov 27, 2012 | Televison & Video
My Vizio Bluetooth remote with keyboard has stopped working. I have spoken with Vizio tech supp. to no avail. I have a remote I used with my old TV issued by Charter because I have Charter cable. I want...
you need to contact charter for support on their remote and how to reprogram it for your new tv. for most universal remotes there is setup key or you have use a key combo to press to enter into setup mode and a user's for the cable box may have this info. however, if you do not have or did not get a user's guide then you need to contact your charter cable company for the info needed to get the 2 devices working together. refer to cable co. tech support.
Aug 25, 2011 | Televison & Video
Charter remote will not change channels--I have put in tv code but still nothing--noting on the remote will work except to power the tv on
You will need to program it to your cable box to change channels. Remember, the channels in your tv are coming from your box, so if the remote can't control the box, you won't be able to change channels. Call charter for help on programming remote to cable box.
Jan 22, 2011 | Televison & Video
Just received a new moxi remote because i was having trouble with my old one. My moxi box is a silver motorola box that says broadband media center. my old remote says charter digital on the bottom and...
Do you know what model MOXI box you have? The new remotes weren't programmed to the MOXI 3012 box. If you have the Moxi MP12, BMC9012, BMC 9012F, BMC 9022 you will need to program the remote to the box.
1. Turn on the Moxi STB.
2. Press and hold the MOXI and OK buttons on the remote until the red LED at the top of the remote blinks twice.
3. After the red LED has blinked twice, release both buttons.
4. Using the numeric buttons on the remote, slowly enter 0, 0, 4. The correct entry of this code will cause the red LED to blink twice.
5. The remote is now programmed to operate the Moxi STB listed above. Go to “Programming the TV”.
Apr 01, 2010 | Televison & Video
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
163 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
