I have all the info to enter, I just can't enter it! All instructions I've found are for the previous Prada phone, the KE850, but that's no help 'cause the connectivity setup options are different for the KF900. Also, I've found one set of instructions but THAT doesn't work either because it says to change the access point in the network profile setup page, but the phone will not let me do that. AT&T won't help me because I didn't buy the phone from them, and nobody else seems to know what to do either. :(
Hi.
LG prada 2 for ATT
i think i figured it out. but its just to get mms working for pix messaging. if this is what you need, try this. (i have no idea if att charges any fees for doing this or using mms this way. use at your own risk!)
first go to access points under connectivity and add a new access point.
i dont remember why, but i named mine express.
under bearer enter GPRS
under APN ender wap.cingular
save!
then go to internet profiles and add new profile.
name it Cingular mms
turn on proxy
server address enter 066.209.011.032 (setting for samsung d807)
server port is 8080
access is express (if you did what i did)
save!
now under messaging/settings/multimedia message/multi msg centre...
add new... name it att mms
under mmsc url, use http://mmsc.cingular.com
under mms proxy select Cingular mms (if you did what i did)
Save!
hopefully this fixed it! let me know if it helped anyone out.
ive been searching for so long and i finally figured this method out.
i would like to know if this helped anyone at all. email me at [email protected]
Your phone company are the only people who can set up MMS on your cell phone. They don't allow customers to do this. Call ATT Customer Care tomorrow and do it then. Hope I can help :)
Hi, thanks for your response. Unfortunately I've tried working with AT&T on this but they refuse to help because the phone is unlocked and I didn't buy it from them. I have all of the MMS settings themselves, I just can't figure out the correct way to enter them into the phone -- ie, which options to select in order to enter the settings. Several people have tried to post guides for this, but they're either for the KE850, or I get stuck on one point -- specifically, when setting up a new network profile in the connectivity menu, I cannot select anything other than WiFi under "access points" because WiFi is the only option in the list. AT&T have been horrendously rude to me about this btw, I just thought I'd add that!
