Question about Franke Flair Espresso Machine with MilkMate
Franke flair screen says empty drip tray, it is empty and even i take it out and replace it wipe it dry it still says empty drip tray
GillianPrendergast
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Where can I buy new seals or a whole new drop tray please
Posted on Oct 17, 2018
3 Related Answers
Morten Bergendahl
  • 60 Answers
SOURCE: Empty Drip Tray message
Try to clip off the tray contacts and clean behind them. If they are dirty and wet on the backside the machine will keep asking you for Empty tray. Use a small screwdriver and clip them off from the inside of the tray
Posted on Aug 20, 2009
espressonist
espressonist
  • 1711 Answers
SOURCE: Hi Hope you can help me. I have a Franke Flair
The problem is probably a damage boiler heating element. It have brake out at a point so it making electrical contact with water and so with body and finaly with earthing of the electrical system and thus trips the main fuse which is the erthing protection system.
So you need to replace the heating element. You need also a good inspection to find if their is another reason why the heating element blow up or if its just because of exeed use of the machine.
Good Luck
Posted on Apr 10, 2010
frankecoffee
  • 29 Answers
SOURCE: Hi, Franke Saphira. 'Empty Drip Tray' message
If you keep the empty drip tray message, especially after making a drink or cleaning operation this points to a leak internally on to the drip tray contacts. or from the thermoblock leaking onto the wiring loom behind the front door panel. An engineer will be required to fix this as the correct seals will be needed. I have been a Franke Service Engineer for 15 Years.
Posted on Nov 19, 2010
How do you remove the back panel of the freezer to remove built up ice
Borrow all the picnic coolers you can, unload and turn off unit. You might even need a couple pounds of dry ice.
Then remove the defrost drip tray and empty it. Then its OK to defrost the unit. Trying to remove ice while operating is risky and you may end up with a replacement on your hands. Don't rush it, but sometimes a hair dryer on low can help (Just left inside the door) just make sure it is kept dry.
Feb 27, 2018 | LG Refrigerators
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
I was descaling my exprelia coffee machine.i was asked to empty the coffee grounds unit and the drip tray. I did that and the message keeps appearing. I even turned the machine on and off. Help.
  1. Thoroughly clean the small overflow area in the drip tray. Once the drip tray gets full water flows over a small rim into this small separate part thus triggering the sensor that tells that the drip tray should be emptied. Its waals may get a bit fatty/dirty, and so remains wet and keeps triggering the sensor.
May 23, 2014 | Saeco Exprelia Automatic Espresso Machine
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
The screen says "empty dregdrawer".
  1. Remove the drip tray (it just lifts off)
  2. Pull on the bottom section, this is a drawer which contains the spent capsules.
  3. Empty the drawer.
  4. Replace the drawer and the drip tray.
This video shows how it's done around 6:55: http://www.youtube.com/watch?v=QnJwgnbfmoQ
Feb 28, 2011 | Lavazza 2210
It says driptray full, but it isn't? Any ideas?
Wevhave had ours into the shop four times for the erroneous 'coffee grounds' and drip tray' emptying. They have changed the mother board, chip in the door and even looked at the head gasket and carburettor settings but can't find the source of the problem.
What we have found latelt (it's Christmas so everything is closed for a month) is if we leave it overnight without power, 3 out of 4 times it resets itself.
It's apain if it plays up during the day but mornings brings us a good cuppa more often than not.lesson-get a deLonghi next time, this Saeco brand is more trouble than they are worth.
Nov 28, 2010 | Gaggia Titanium Espresso Machine
I have a Saeco Pimea Cappuccino touch plus cofee maker and it says in the screen to empty the drip tray under the brewer goup. I have done several times, washed the dtray, fdried it and put it back in the...
Hi Darrell,...Make sure the part of the machine where the driptray fits is all dry.(no wet ground coffee stick on the wall) Itis possible the water sensor inside the machine is sensing wetness behind the drip tray. Hope it helps.
Aug 15, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Aug 17, 2009 | Franke Saphira Espresso & Coffee Maker
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Franke Flair Espresso Machine with MilkMate Logo
979 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Dennis
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
