Question about Sony PlayStation 2 (PS2) Console
Playstation2 not reading dvds
My playstation2 is playing games just fine but when i put dvds in, it always says disc read error no matter what dvd it is. how can i solve this problem?
Posted by fisher_matt4 on
Anonymous
Clean the eye on the playstation
Posted on Mar 18, 2009
1helpful
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
1helpful
2answers
PS3 will play blu-rays just fine, but not DVD
A bad laser could affect the sound cause it can't read all the information from the disc. Try games as well and see if it does the same thing, sounds like a new drive is in order. There is one laser in those drives and require different strengths to read different discs. Also try a music disc that you know is good. If your still getting the same issue then get the drive replaced or just replace the laser if you have some technical knowledge.
2helpful
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Playstation2 DVD read error ''The disc could not be read''
I've encountered similar problem with my PS2. I really can't play the disc that I bought. There might be some burning problem that difficult to read by your PS2. What I did I've tried to copy it and burn in to a better DVD disc and it works. Try it.
Will not play games
Make sure discs are not scratched. Try cleaning the discs using rubbing alcohol and a soft cloth.
Will not play a game
this usually happens to bad/damaged/dirty game disks. try cleaning the disks. if that doesn't work, contact microsoft via xbox.com/support.
2helpful
SAMSUNG SV-DVD440 Combo
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
2answers
DVDs won't play (but CDs will)
Did you try to clean lenses on laser head?
5answers
Sony play station 3
ps2 discs are region locked ps3 games are not so are some dvds the are region locked if you seriously want to play the ps2 games buy them from japan
3answers
DVD problem
Have you tried several DVDs? Maybe it doesn't read some types of DVDs.
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
Oloyede Monsuru
Daniel Dollive
Daniel Dollive
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
