What is your REM terminal connected to on the amp? It should be connected to the blue wire on your head unit. If it is not, then that's your problem. It sounds like you may have it connected directly to the battery, which is keeping your amp on all the time. The REM is the turn on signal for your amp.
the red light stays on when the car is on and off. stays on constently. never turns off... im lost
You need to confirm that the remote voltage is going to 0v when the head unit/ignition is switched off.
