Question about Motorola Mobility KRZR K1m Cellular Phone
SD card issues
I have a MOTOKRZR K1m and I also have a 4gig mini SD card. For some reason, when I insert the card, the phone takes forever to boot up, and if I don't get a "No Service" phrase on the phone, my PC does not recognize the SD card.
Posted by mortleysmith on
  • mortleysmith Mar 18, 2009
    Thanks very much. I called the Motorola customer service line and they said that the K1m only supports a 1 gb card. I'll be talking with my vendor as that seems to be pretty important information to pass along to future customers. Thanks again for the solution.
Anonymous
  • 32 Answers
Ur mobile does not support the 4 gb card its capable of supporting only til 2 gb so try a 2 gb card it wil be fast as old times
Posted on Mar 18, 2009
Motorola krzr k1m + 2gb memory - won't read the card
for your added information, it is by chance that the 2 gb sd card can be recognize by your phone. normally, krzr 1 doesn't support 2 gb. you may think that others do have. it all depends on the firmware they have and sometimes on the brand of the sd card like micromax
it is really by chance that it will be recognize. most of the time, it can be hardly recognize.
take care.
2answers
Formating my k1m krzr
take micro sd out of krzr..put the micro sd in the adapter (fits in slots on pc / laptops) go to.my computer, find drive, right click,format..take out re-insert to krzr
bye-bye
2answers
Problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
I guess you put the SD adapter into the card reader right out of the box? You first may have to partition/format it after unpacking it. Under WinXP I can recommend an utility "DiskPart" which you can start from the command prompt (Run... -> cmd). For further instructions (if it sounds to you to be the problem ) contact me again.
3answers
IPAQ 6515 doesn't recognize new HP 8Gig SD card when inserted. I reset but nothing happened. Any idea what the problem might be.
I am sorry?
You want me to give you my solution for nothing and want to charge me $9.95 for it.
I could not find any posted solutions when I checked your site.
Help!!!
Hi I got the same phone today.
I assume you are trying to install the SIM card as you stated and not the memory SD card as some are talking about.
My manual just shows a picture!
Take out the battery hold the phone with the bottom toward you look at the hole where the battery was.
On the bottom of the square there is a slot in the middle that the SIM card slides into.
THE NOTCH ON THE SIM IS TO THE BOTTOM LEFT CORNER.
Place the SIM card flat against the bottom of the hole where the battery was with the notch as stated and slide it down towards you into place. The SIM just about disappears into the bottom edge of the battery hole. Thats what my manual showed about inserting theSIM card.
Haven't inserted a SD card yet.Hope this helps.
4answers
Motorolat MOTOKRZR K1 File Transfer
the driver was not installed properly. Motorola has downloadable drivers on their website. check with them for dowload instructions. If you still have trouble you may want to install motorola phone tools. It is synchronization software by motorola. costs about $30
1helpful
5answers
Motokrzr k1m
The K1M only takes a Transflash card. Remove the battery cover, and at the bottom, you will see a small rubber cover. Pry it out with a fingernail, and insert the Transflash card to to the left. Replace the rubber cover and the battery cover.
3helpful
5answers
Krzr k1m won't connect to bluetooth device
Turn off the phone. Remove the micro-sd card. Restart phone. It should connect now.
2answers
SD Mini card
The best way is to do it through your computer
Motorola Mobility KRZR K1m Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Fred
Fred
Vernon Taylor
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
