Cameras Logo
Anonymous Posted on May 15, 2013
Poor image quality
4x6 print looks terrible (very pixelated). It's a 12 megapixel camera set on highest print quality. I didn't digitally zoom either.
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
  • Posted on May 16, 2013
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86401
Points
1069
Can u post the image ...so i can have a look
5 Related Answers
Anonymous
  • 903 Answers
  • Posted on Sep 04, 2005
SOURCE: Best picture size to use
The higher quality will not degrade the prints, you can always reduce the size for printing, if you wish. (Although it shouldn't matter, if the printer is not able to print all the pixels due to limited resolution, it will downsize properly, anyway). The only drawbacks are, as you noted, increased size/storage requirements. I would shot always in the biggest possible size and with fine JPEG (no sense in using TIFF - the quality is not so different that you ever notive it). The reason for always using the biggest size is that you can later crop and have better chances at postprocessing. When "THE" shot comes your way, you don't want to accidentily store it in all the glory of 800x600 pixels :) (Switching sizes is a bad idea, you inevitable forget to switch the size back and shot an entire afternoon in the small size. Been there, done that, did not get the pixels back :)
A
Anonymous
  • Posted on Oct 25, 2007
SOURCE: Image looks with white verital striped lines in playback mode
Mine had the same problem (except the stripes are horizontal).  I sent it to Canon and sure enough it is the CCD problem that many of these have.  The good news is that it is covered under a recall and Canon will fix it free, including the shipping.
Anonymous
  • 480 Answers
  • Posted on May 13, 2008
SOURCE: I purchased a d80 recently
Hey mcgeedds,
What you’re seeing is probably what is called digital noise. At low levels of light the sensor in the camera that records the image shares data from one pixel to the ones adjacent to it which causes digital noise. The way to fix this is either make sure your noise reduction setting is turned on, or get a powerful off camera flash that has the power and coverage capabilities to light the subject at the distance you are from your subject. Noise reduction on average should double your exposure time requiring you to use a tripod in most cases. Also pay attention to your iso setting if it is too high this can also cause digital noise in your images. I almost never shoot with a higher iso that 400. I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
Anonymous
  • 121 Answers
  • Posted on Dec 30, 2008
SOURCE: Pixel problem, all pictures taken have poor pixel resolution
It sounds like you set the file settings to a small file size - perhaps in order to get more photos on a single memory card. You need to change the setting to the largest file size possible, at the highest quality. The steps for this will be in your manual. If you need detailed instructions and don't have your manual, let me know and I'll lookup your manual online.
fertobar
Fernando Tobar
  • 35 Answers
  • Posted on Aug 07, 2009
SOURCE: megapixels on camera needs to be reset?
Check the sizes and quality pressing the FUNC button while in shooting mode. The left side options on your screen, at the left bottom corner will display the size and compression for the images, and select the desired size. See the manual for the correct size which corresponds to proper printing size. I suggest you to use always the maximum size for the S3: 6MP and compression at superfine, no matter what the size of your prints will be. Always check your SD card. A good practice is to carry a second SD card. 1 MB is OK if you don't use the camera for videos.
Is a good practice also to check always some basic settings prior to use the camera.
Hi there I just bought a Polaroid two instant print camera but the quality of pics is really poor very washed out and even a bit blurry do I need to set it up?
set your pixel ratio to the largest setting, this means less pictures per memory, but higher picture quality. Also if possible adjust your iso to the highest setting, as well as the shutter speed, having both of these settings set to the highest point will require more light for picture taking, however will result in the highest quality image.
1helpful
I have kodak printer 5210. when i print a picture on 4x6 card. it looks good. but when i try 8x10.5 it doesn't look good. It looks little blurry.
The problem is probably the pixel size of the picture. Pictures with 5 or 6 megapixels look fine on 4 x 6 but they get blurry when enlarged. You need a minimum of 10 megapixels for an 8 x 10 print. Cameras that are able to take 10 megapixel or higher photos normally don't do this by default. They are set to save more photos on the memory card of the camera and so save the photographs as lower quality snaps. These are fine for looking at on a computer but if you want to print at 8 x 10 you need to set your camera to take the highest quality photo.
What image resolution should i be using for regular 4x6 prints i have a 10.1 megapixel camera, but my pics still look grainy
Your pictures should not be looking grainy. Are they printed grainy but look clear on your screen. If so then it's just your printer. Try forcing the flash in the highest resolution. If you video's are grainy too then there is possibly something wrong with your camera. Make sure your lens is really clean. Worst case your CCD sensor inside your camera could be bad. Hope not!
Image qulaity problem in fujifilm finepix fd50
It sounds like the resolution on the monitor may be set incorrectly in Photoshop. Try a different monitor setting. Twelve megapixels may result in your monitor "seeing" so many pixels it tries to ignore the excess ones, resulting in an image that looks poor on your monitor. If you order one print, that may give you an idea of the true printed quality without spending a lot of money on a bunch of bad prints. The F50 is truly an excellent camera and gives super images, from my experience.
Mar 02, 2008 • Cameras
Quality too low for 4x6 prints
A P72 should be good enough for 4x6 prints. Are you shooting at the maximum resolution? At 3.2 Megapixels you should be able to print at 4x6" at 250dpi (which although not ideal is better than that of most magazine printing!)
The graininess of your images is not to do with resolution but rather sensitivity and the processing engine in the camera. Are you shooting in bright light, or mainly with the flash? If it is the latter, I'm afraid you're always going to have the picture noise (graininess) with this camera.
If you're going to upgrade, look for a model with good low light capabilities and a good lens. www.dpreview.com is an excellent resource for comparison shopping.
Poor resolution when using internet sites
There is no setting on the camera. I would recommend checking to see what resolution your online site has set for max resolution. Also, make sure that you are not just downloading thumbnails to your computer instead of the actual image file. I really recommend using Microsoft camera scanner wizard to save pictures into a my pictures folder. Have never had any trouble with that program. Hope that helps.
2answers
Digital Resolution for 4x6
You will need all the pixels the camera can produce so set the camera for 1600 x 1200 Fine. That should produce a good 4 x 6 print. I can't help with auto/manual as I do not know what they do on that camera.
Highest still image quality
SV-AS10, SV-AV25 & SV-AV50: 1600 x 1200 pixels (printing 4" x 6") SV-AV100: 640 x 480 pixels.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
