The wiring diagram is on the last page of the manual at http://www.jvc.co.nz/assets/pdf-manual/KD-R526.pdf
SOURCE: Where to get manual for JVC kd-lhx501
Hi - You can download the manual from the link underlined in blue below:
kd-lhx501
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Can I use a Chrysler/Infinity amp with aftermarker JVC radio?
it wouldn't be advised unless there are rca connections into the amp. these are the same as the inputs in the back of the jvc. It is possible to connect into an amplifier using speaker cable but i wouldn;t advise doing this unless you know what your doing.
SOURCE: need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
SOURCE: Car radio connections
Red wire to acc fuse
yellow= b+ fuse
blue= to amp amplifier
white= +left front speaker
white/black left front - front speaker
gray= + front right
gray/black= - front right
green= + rear left
green/black= - rear left
purple= + rear right
purple/black= - rear right
black = ground---to car metal
orange with white line to illimination
