Square enix the game does not want to open, it is installed on my pc but when i open it or run it, nothing happens, not even the black screen appears, what is the problem?
    New Friend:
  • 60 Answers
It could be it is not compatible with the computer you installed it on. If you look on the back of the package and see that your computer does meet those requirements I would usually just reinstal the game using the recommended setting.
Posted on May 17, 2013
3 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 5 Answers
SOURCE: toshiba setellite black out
Sounds like the back light on the screen isn't working properly which will need to be replaced if this is the case. Check for a very dark image on the screen when it is booting up in a well lit room, if you can see the computer start up then it is the back light.
Posted on Jun 25, 2008
sumantapani
Sumanta Pani
  • 32 Answers
SOURCE: nothing appears on the screen
press the power botton .
It might got into hibernate mode.
Posted on Aug 19, 2009
Cant install infernal the game on my PC
http://support.eu.square-enix.com/faqarticle.php?kid=59049&ret=main&id=2147&la=2&pv=20&SQEXSC=f7do7u05ncttoh4rt9gl19amp6
KB Article: 59049
KB Category: [Technical Support]
KB Sub-category: [ Installation]
I cannot install the Tag?s driver on Windows Vista and the game will not run wthout them, what can I do?
Infernal is copy protected with \Tag?s\". This requires you to install a Tag?s driver which is found on the game disc and should be installed when the game is installed.
Unfortunately the Tag?s drivers on the Infernal disc have not been Vista certified. If you are using Windows Vista you won't be able to install the Tag?s drivers and to start the game. You need to download and install the following certified drivers:
http://www.tagesprotection.com/main.htm?page=5.5.htm
Apologies for any inconvenience.
FYI THIS IS A FIX FOR WIN 7 as well x64 and x86
Jan 16, 2012 | Eidos Interactive Infernal for Windows
When trying to install the FFXI it goes to a black screen and stays like that and nothing loads up
There is a couple of things that you can try here first off.
The condition of the disk if there is any scratches on it please get it repaired from a video game store or a movie store.
If you have a weak or slow internet connection you may need to borrow a buddies connection.
If it is not installing it on your hard drive then try it out on another machine to see if it is the game or the machine.
if the game is the issue then get it repaired or replaced.
if the system is the issue then the laser lens may need to be cleaned or replaced
May 29, 2011 | Square Enix Final Fantasy XI for Xbox 360
Hi,I'm having CFW 5.50 Prome-4.I downloaded FF7 Crisis Core ISO from the internet and when i wanted to start a new game.after selecting new game it just shows me a black screen but the power button is...
It seems like you have a broken ISO from the internet, I would suggest the following measures.
1. Redownload the ISO, it may be corrupted. Try to download it from another source.
2. This is more severe, but it might help in the long run: re-apply the update for your CFW, meaning, reformat your PSP, apply the update and the CFW again.
Hope these tips help :D
May 17, 2011 | Square Enix Crisis Core: Final Fantasy VII...
Play screen comes on then says disc is unreadable
your game is not right downloaded because probably is a piece of the game but i think is not the full game so try to download it somewhere other website and try it again.I hope it helps
Apr 11, 2010 | Square Enix Final Fantasy XI for Xbox 360
Ff 11 game crashes at character login screen just goes black and im unable to do anything but turn the xbox off
for some reason your xbox is taking a long time to connect to the Square Enix servers. I can only suggest you make sure to have your cache cleared for a smooth load. You may have to redownload the game.
Jan 03, 2010 | Square Enix Final Fantasy XI for Xbox 360
Kindom Hearts II Freezing
Possibly the disk, you need to clean it with disk cleaner.
If the trouble still persist, it's the lens problem.
Open the case, then the mechanical case, after you see the lens, use a soft cotton buds, then put it in alcohol, then rub the lens firmly.
After that rub again with cotton buds without the alcohol, that should fix the problem.
Oct 23, 2009 | Square Enix Kingdom Hearts II for...
My game fades to black and doesnt go away
Sounds like a disc error. I'd check the disc or if possible, go grind levels a bit somewhere and return to the commencement, it might free up the problem. Square Enix sometimes let little things like this fall through the cracks on otherwise awesome games! If nothing else, just borrow a copy to get through that area then you should be good to go!
Sep 12, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Stuck in the dragonbone shrine in infinite undiscovery cant get past the door that demands black wings and poisonous fangs
use rico to penguin march a bloodsucker and a thorn cobra to the door then it should unseal it oh and use both the kids to heal and conserve mp good look
Apr 12, 2009 | Square Enix Infinite Undiscovery Game for...
Computers & Internet Logo
26 people viewed this question
Ekse
Marvin
Marvin
