Microsoft Windows 7 Ultimate for PC Logo
Anonymous Posted on May 15, 2013
Lines down page
I have windows 7, currently i have 26 lines running down my page-do you have any thoughts on how to remove there
Sanath Kumar V
Level 3:
  • Master 684 Answers
  • Posted on May 15, 2013
Sanath Kumar V
Master
Level 3:
Answers
684
Questions
Helped
164912
Points
1521
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Safe Mode. Once its selected, Logon to your Username and let me know if you find the same issue.
How to remove iexplore.exe virus from windows 7
We first recommend you to update your anti-virus software and thoroughly scan your system (if you have not done this already) and follow the virus removal process guided by your anti-virus software.
If this does not resolve your issue, you can refer to the Microsoft Support page below to follow the standard virus removal procedure for Windows 7:
(Important: Make sure that you select "Windows 7" from the drop-down menu at the start of the page to refer to the correct procedure.)
http://windows.microsoft.com/en-in/windows/how-remove-computer-virus#how-remove-computer-virus=windows-7
If you are still facing the issue, you need to contact Microsoft Support through the following link for further assistance:
http://support.microsoft.com/contactus/?ln=en-us
GuruAid.com
BOOTMGR is compressed
I will give you a link with detailed instructions to fix this problem but first you need to be sure you have a Windows 7 or Windows Vista (whichever version you're currently running) recovery or installation CD or DVD and a working CD/DVD drive. That said, here's the link (just look about 1/4 of the way down the page for the instructions).
How to fix BOOTMGR is compressed error in Windows Vista Windows 7
1helpful
My Samsung NC10 notebook will not detect my projector
Well, to narrow down the problem, let's try making sure your graphics drivers are current to what the manufacturer recommends. You can find the support page for your model here:
http://www.samsung.com/us/support/owners/product/NP-NC10-KA03US
Just click "Drivers" next to where "Manuals" is currently selected. You can also try updating your Chipset driver as well, just to be thorough. If you are running Windows 7, be sure to pick the Windows 7 version of the drivers. Download them and run the self-extracting utility and then setup.exe.
Hopefully this will fix your problem.
I have a Ricoh sp c222sf multifunction machine. I'm running Windows 7. I loaded a driver for both the printer and the scanner from thier website. All seemed well until I went to scan from the ADF. It...
u got to unscrew the scanner a bit and arange the adf left or right depending your line position. the adf is not positioned perfect on the machine , and at the end it scan the adf back , thath is the line come from on your scanned document
2helpful
2answers
There is a compatibility problem between Windows 7 and HP products (my product is the HP Color Laser Jet 2840), that causes error messages when printing documents - "Page too complex", long...
My firts thought would be to make sure I have the updated driver from my printer and operating system.
If you are running Windows you can make use of an automatic on-line driver check program to verify you have the most current drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=115&prodTypeId=18972&prodSeriesId=445194
If I do not have the most current driver for my sysytem I would uninstall my current driver, and download and install the most current driver from:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=444735&
This should resolve compatability issues. I think then you could deal with any individual error messages that might occur. Ther e are several liks that may help on the above page.
Trust this helps resolve your problems. :)
How do i change my home page? i want it to gateway
hi
Internet Explorer for Windows
1. Browse normally to the web page you want as your home page.
2. Pull down the "Tools" menu of Internet Explorer.
3. Select "Internet Options."
4. The "General" tab appears.
5. You'll see the "Home page" box at the top.
6. Click the "Use Current" button in that box.
7. Click "OK." \
8. Close and open Internet Explorer. You should see your new home page.
Firefox for any operating system Changing your home page in Firefox is easy. Just follow these steps:
2. Pull down the "Tools" menu of Firefox.
3. Select "Options."
4. Click on the "General" tab, if it is not the first to appear.
5. You'll see the "Home Page" box at the top.
6. Click the "Use Current Page" button in that box.
7. Click "OK."
8. Close and open Firefox. You should see your new home page.
Safari for MacOS X
Changing your home page in Safari isn't tough either:
2. Pull down the "Safari" menu.
3. Select "Preferences."
4. Click on the "General" tab.
5. Note the "Home page:" field and the "Set to Current Page" button beneath it.
6. Click "Set to Current Page."
7. Click the red "close" button in the upper left corner of the preferences dialog.
8. Close and open Safari. You should see your new home page.
Opera
Opera changes the home page in pretty much the same way as the rest:
2. Pull down the "Tools" menu.
3. Select "Preferences..."
4. The "Preferences" dialog box appears. Click on the "General" tab.
5. Note the "Home page" field and the "Use Current" button to the right of it.
6. Click "Use Current."
7. Click "OK."
vote me if you have your solution
Will Pinnacle Studio 12 Ultimate run on Windows 7
According to Microsoft, YES IT WILL. Pinnacle Studio 12 appears to be completely compatible with Win7. Below is the link to the Microsoft page.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=Pinnacle%20Studio&v=Pinnacle&uid=12&pf=0&pi=1&c=Photo%20%26%20Video&sc=Other&os=64-bit
I have to add that I've never tried to run Pinnacle Studio 12 on Win7.
1helpful
2answers
How do i change my homepage to Yahoo?
Bring up the browser window and let it load to whatever page it is set for. Once it loads, click up in the address bar and type in www.Yahoo.com and click enter. When the Yahoo screen loads, click on the "Tools" column and scroll down to "Internet Options". In this window the first area you see is the homepage tab. Click on "Use Current", this will make the current page your home page, which is Yahoo. Click apply and OK.
My search results return a blank white page.
If you are running with Window XP then please see this and follow the instruction given by me:
Use IE 6.0 instead of IE 7.0
or use a new Web Browser such as Firefox or Google chrome, see this Tip posted by Me:
Google Chrome for All XP or Vista user
Let me know in either case if you have any issue remaining, dont vote till you get the solution.
Scott
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
