RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture won't fit in screen
I can't find a setting to adjust the screen so the picture fits in the screen..the heads are cut off...it used to work on Autoadjust, but not now.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Mar 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
1566
Points
6
Sounds like your screen aspect ratio is off. IMine did the smae. I took it off of autoformat, and just moved the left/right buttons beside the ok button until the screen was on 16:9 all the time. Also directtv, dishnet and some cable boxes have an aspect ratio on them. You may need to go in and adjust it to 16:9 as well.
Anonymous
Level 3:
Genius:
  • Master 1,030 Answers
  • Posted on Mar 18, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1030
Questions
Helped
227552
Points
2244
First is the picture is distorted? if no then try using the remote and push the left or right arrow keys
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
1helpful
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
3helpful
2answers
Picture is too wide to fit screen can not see complete picture
hi there, i don't know your TV brand but this could be of help anyway. there is an adjustment for horizontal and vertical width. you can manually adjust the setting until it fits the picture on the screen. for standard TV it has trimmer in the CRT board. If in your case you have a soft adjustment in the remote control try to adjust it. Learn how the menu works just look for the picture adjustment.
Good luck, please rate and vote.
4helpful
2answers
Picture too large for screen
Press "wide mode" on TV remote until it is on "full". Check for same on set-top box.
LG 42 inch picture does not fit on the tv screen horizontally
The format is set incorrectly. Go into the Picture settings in the menu and adjust the format settings until you get the size picture that you like.
Craig
Picture doesn't fit in screen
You're looking for something that will adjust aspect ratio.
2helpful
Picture doesn't fit the screen
Try locating the aspect ratio adjustment on your cable box if you have one.
Picture got bigger
Yes, you can adjust the picture by using your remote going to settings, or "Adjust" when your t.v. turns on and off by itself could have'ft to do with nasty weather near you, or the cord is loose and it needs to be pushed in all the way.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
