Question about Windsor SR12 Sensor Bagged Upright Vacuum
Windsor sensor says bag is full when its not
I put a new bag on and its only lasting about 3 vacumnings before the machine is automatically shutting off and flashing "Bag Full". The bag is only maybe 1/3 full.
Posted by bkmorg on
  • Lbeights Mar 24, 2009
    I have the same problem.  Put in a new bag and the "bag full" light immediately started flashing.
  • Anonymous Mar 25, 2014
    We had a flood the vacum got wet but I let it dry out but the full bag light sensor stay on and shut the vacum off
Anonymous
  • 58 Answers
Are you vacuuming up fine particals like pet dander or just large amounts of regular dust? Also when was the last time you replaced your filters?
Just some sugestions.
Posted on May 29, 2009
Anonymous
Underneath the machine is an inspection door to check for blockages. To open the door, press down the catch on the door.
Blockages in the neck can be checked by first lifting off the dust bag housing.
Posted on Aug 15, 2009
cuda69
    New Friend:
Seems the newer Windsor Sensor units have a bit of a problem with this. If a new bag doesn't work, the problem may be in the bypass valve switch. I have a few of these units and have had the bag light come on even with a new bag. You need to dismantle the whole unit to get to this switch (valve) though so don't try it unless you are confident that you can get it back together correctly. Windsor part # 2835 (bypass valve).
Posted on Aug 10, 2011
  • 1 more comment
  • Crayolabear
    Crayolabear Oct 19, 2013
    How do you remove the swivel neck assembly to get to the bypass valve switch. I can't to get it off. each of the swivel neck supports will not come free from the frame. Am I missing something here? Please help me. Thank you
  • Eric Bronson Sr.
    Eric Bronson Sr. Mar 09, 2014
    were is the valve switch located?
  • kyle collins
    kyle collins Dec 05, 2014
    how do you test the bypass valve. I was able to get to it but how would you test it to see if it working
Randy Russell
This is a common problem. I work for a school district. I solve this problem by removing the by-pass valve, dismantling it (10 parts), cleaning up the parts, reassemble. Dust collects on the metal terminals and provides electrical resistance causing a malfunction of the by-pass valve. I can do this procedure in about 20 minutes from opening chassis to closing chassis. You can try adjusting the by-pass valve with a small flat blade screw driver without removing the unit, but that is hit and miss. NOTE, there is a black foam filter that gets clogged with dust at the swivel neck. This part is NOT in the manual. Extend the bag housing down to the floor or remove it completely and look to the right of the swivel neck. There is a black plastic grate and the foam filter is behind it. This is an air inlet so dust will collect there and dust will eventually get sucked inside chassis covering the power supply and getting into the by-pass valve. Regular cleaning from the outside by the user will help decrease the amount of dust entering chassis. Hope this helps.
Posted on Feb 26, 2018
Traci Gardner
    New Friend:
Just had this problem today. Since the bag wasn't full when I took it off and the light came on with the new bag, I knew it had to be a clog. Opened the little orange door on the bottom of the machine (just behind the brush) to check for a clog there. Checked the filter, still very clean. Took the hose off and blew it out with an air hose and voila - a little plastic toy and a few big dust balls came out. Works like a champ now.
Posted on Mar 09, 2014
Where is vacuum chamber on a Windsor sensor xp12
it comes up from the back,it is probably plugged or the sensor is dirty
Apr 21, 2015 | Windsor Vacuums
I have windsor s12 red light for bag is full is on and it's not clogged. what next
Check the line going from the bottom of the vacuum to the bag, it may be clogged. A coat hanger can help you clear any jams, but be careful not to puncture the duct.
Jan 27, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
Windsor sensor vacuum lights flashing then motor shuts off
I've worked on these a lot. What I think you're explaining is the bypass flow switch which is a common failure. It's located in the base inside the auction side of motor housing...
May 01, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
I have a Windsor Sensor s12 and power shuts off after 5 min. of vacuuming. I'm wondering if it's overheating of if there is some other sensor that causes it to shut off.
Your Sensor most likely has an internal heat sensor that is shutting off the motor. Some vacuums install an external heat sensor with a reset button that you must push to re-start the vacuum. If your model does not have an external reset button it is most likely a sensor inside the motor. If it is defective the motor must be replaced to solve the problem. But first make sure the overheating is not being caused by a blockage somewhere or the bag is too full. Air must pass completely through a vacuum starting at the floor where it picks up the dirt through all the canisters, filters, bags, etc. and then is exhausted from the vacuum. Any restrictions or blockage can cause the motor to over heat.
That Vac Guy
Jan 04, 2013 | Windsor SR12 Sensor Bagged Upright Vacuum
Vacuum shuts off and on while trying to vacuum
check power cable for brakes and cracks, replace if need be..
Nov 18, 2012 | Windsor SR12 Sensor Bagged Upright Vacuum
Sensor xp 15 shutting down
If you have one of your red lights flashing or on all the time that will indicate where you need to look for your repair. Beater bar light will indicate a brush roll replacement and the bag light indicates a need to empty the bag or look for a clog somewhere in the air flow area of the hose or wand. These machines are designed to shut down if you keep trying to run them with a red light coming on.
Aug 25, 2012 | Winsor Windsor SENSOR XP 12 Vacuum
How do you change the belt on a winsor sensor s12?
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Windsor vacuums.
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Apr 26, 2010 | Windsor SR12 Sensor Bagged Upright Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Windsor SR12 Sensor Bagged Upright Vacuum Logo
6,582 people viewed this question
Top Windsor Vacuums Experts
Mike
ray gallant
brian kossman
Level 1 Expert
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
