My Lexmark x3430 has worked great until today when it started only feeding on the right side. There is a message continuously saying to load paper. I AM TRYING
SOURCE: paper feeder won't follow through
The feeder mechanism has so to speak come undone and the printer needs taking aprt and putting back together with the feeder and the cogs interacting with eachother. Ther is a small metal clip lick tensioner to keep it in contact with the cogs, if the clip has come off it just needs securing back in place.
SOURCE: Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
SOURCE: lexmark x83 paper feed problem
If your not qualified to do this I would not sugges you do it, tho here is a solution for you. See if its snapped in place instead of being bolted down. you can also access underneath the unit hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
