HP OfficeJet t45 All-In-One InkJet Printer Logo
Posted on Mar 17, 2009
Hpt45 will not work on Vista
Without spending money, hp does not have t45 driver for vista, can I make Vista patch over to xp to run my hpt45 or How to use my hpt45 with my vista
  • Anonymous Mar 30, 2014
    Hi, yes U can use T45 as a printer under Vista by downloading and installing HP DeskJet 895Cse drivers from HP site. Good Luck
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Oct 22, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
1913
Points
11
You can also try the Officejet R45 driver, as this seems to support most printing functionality and quality of the T45, including color output.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
772
Points
6
You won't need the T45 driver for the Vista environment...just add HP OfficeJet V40 from dropdown list.
A
Anonymous
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Feb 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
998
Points
7
Also for printer part only, you can use DJ896 drivers, from HP
  • Anonymous Oct 22, 2010
    I've also found that the Officejet R45 drivers work well, color printout and all.
My T 45 office jet will not down load drivers for vista ?
HP did not release a driver for any version of Windows higher than XP
You will need to manually load the XP drivers for your printer.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=60398#N191
2helpful
2answers
Cant get to work with new computer
To support the Officejet T45 in Windows Vista, install it using the Officejet R45 drivers. Color printing and high resolution output is supported using that driver!
2answers
HP Officejet t45 All-in-One vista driver, any ideas?
Try the HP 950C as your driver for the T45, it worked on mine.
I have vista operating system are there drivers for my hp T45 officejet All in one?
There are no official drivers for the T45 in Vista. You can, however, use the Officejet R45 drivers instead. It seems to work well, and supports color printing.
2answers
I have a hp officejet all in ne printer and i have up graded to windows vista i can not load my printer and can not seem to down load a driver for it can you help please
use the Desk jet 890c driver built in to Vista. Use the Add Printer command and choose the Desk jet 890c from the printers listed.
check it .....
HP 1610v all-in-one and need patch to run w/Vista
try using the same driver but just go threw the device manager then right click update driver and click find the driver on the computer and find the driver from the xp file if thats what your operating system was before and use it, it will take the driver out to use it that might work or you could right click on the file and click properties then click compatibility and find the operating system you was using before then click apply
4helpful
2answers
Need software to install HP OfficeJet T45 printer to my Vista PC
I had the same problem, but was able to use my printer by adding HP OfficeJet V40 instead from the dropdown list. I didn't need to bring in a driver. Try it...it worked for me.
3answers
Driver problem with vista
Unless there is an overly compelling reason to be using Vista roll back to XP, wait a few more months for the new drivers. Vista I'm sure has just been developed to keep mental health proffesionals in buisines. Failing that you can often "trick" XP drivers to work on Vista ocasionaly even got a few 2K ones to work.
Obviously hit them manufacturers web site. But don't be so sure. Had to abandon a printer because just no drivers for Vista.
Go back to XP - Vista offers nothing of significance over XP and with service packs is nice and stable - Vista at this point in time does not play nicely with others hardware or software.
7helpful
3answers
Hp officejet 5610v all in one insallation software for windows vista
Try this link. It is the full intall file for the all in one being run on a Vista Machine. It worked fine for my installation.
Muck around on the site for a bit, and you can also find the same install file for Windows XP.
Good Luck
http://hp.driversdown.com/hp-drivers-download/HP-Officejet-5605-5610-5610v-5610xi-All-in-One-Driver-080.001.237.000-for-Windows--Vista-(32-64)_9168.shtml
9helpful
2answers
Windows vista says no to oldschool
After Vista servicepack1, your HP4200C Scanjet should work if you use the latest drivers from sj655en.exe downloaded from HP.com.
k24674
Grand Canyon Tech
Grand Canyon Tech
