Bushnell Weather FX7 7 Day Forecast AccuWeather Stations - 95 Logo
Question about Bushnell Weather FX7 7 Day Forecast AccuWeather Stations - 95
Weather FX7 not changing
The temperature on the unit does not change unless I change the location then go back to the original location.
Posted by Lloyd Earnest on
Frank Perretto
    New Friend:
  • 23 Answers
I have the same unit and have had the same problem . There should be at least two to three bars on the most upper right hand corner of the screen which pulls in the updated conditions If you have none I have tried , there is a tiny pin hole on the bottom back (center) - with a small pin I stuck it in and the unit rebooted an works fine now
Posted on Mar 18, 2015
Change Location Digitech XC0366 weather station
Page 6 of the manual refers
DIGITECH XC-0366 USER MANUAL Pdf Download ...
www.manualslib.com > ... > Weather Station
Temperature Alert Setting: You can program your weather station to sound an alert whenever the outdoor temperature exceeds the upper or lower pre-set limit.
Outside temp read 80.Smart phone weather said 70.Replaced batteries and did all the troubleshooting. Model 0041/00609SBDIA/00611A3. Less than 1 year old. Inside temp works, dashes on outside reading.
Place your remote temperature sensor and the inside unit together for about an hour to see if they both read the same or if there is a large difference in the temperatures.
Dashes on the outside temperature reading may indicate that the inside unit is not receiving a signal from the remote. Change the batteries on the remote or change the location of the inside and/or outside units so that they can receive a strong signal between each other.
Your smartphone temperature may be coming from a location that is not near your home. They are often from a weather service. Where is your local temperature sensor located? Is it in the sun? Is it on the south side of the house, or another location where the sun or an air conditioner or other heat source may affect the accuracy of the reading? Try to locate your outside sensor in a shaded location with plenty of ventilation, and away from heat sources.
1helpful
How to change Fitbit Vera’s weather from Celsius to Fahrenheit
How do I change the weather from Fahrenheit to Celsius on my Fitbit versa? To change the units used for the temperature in the Weather app:
  1. From the Fitbit app dashboard, tap or click the Account icon > Advanced Settings > Units.
  2. In the Length section, select a different measurement. ...
  3. Sync your watch and then open the Weather app on your watch to see the updated units.
How do I change from Celsius to farenheit
  1. Can I still switch my temperature from Fahrenheit to Celsius
    feedback.weather.com/.../24423-weather-com-can-... The Weather Channelweather.com - Local Forecast / Maps / Video. Yes, you can switch the temperaturescale for any location on weather.com from Fahrenheit to Celsius, and back ...
1helpful
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
I CANNOT GET MY OUTDOOR TEMP, TO CHANGE, HAS NEW BATTERYS AND POLARITY IS CORRECT. PLEASE HELP, THANX
Hi Jim, what make/model station do you have? Normally there is a search function on the main unit to find the outdoor unit. After that they should sync and the outdoor temperature will reflect the temperature of where the outdoor sensor is located.
Hope this helps.
15helpful
Changed batteries and the outside temperature still does not show
Bring the outside sensor inside. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the remote sensor. Put the batteries back in the main unit. Do not touch any of the buttons. Wait 10 minutes. If the remote temperature is not showing within 10 minutes, try again. Once the remote temperature is showing, you can set the clock.
Top Bushnell Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Are you a Bushnell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
