My refrigerator keeps shutting off-I restart it- it runs for a little bit and shuts off again.. just wondering if I need a new theromstate
SOURCE: Problems with Frigidaire FRT18HB5DW0 Top Freezer Refrigerator
may be your thermostat is easy to cut off or not functioning ,pls check the thermostat .
Regards,
Edgz
SOURCE: Refrigerator door won't shut
Check to see if the door gasket has forzen water that is preventing it from collapsing like it should and wedging the door open. This would most likely be on the hinge side of the door.
Also make sure the gasket is not bent or warped and binding as it closes.
Let us know if you find nothing wrong there and we can look further.
SOURCE: refrigerator compressor makes a loud rumble when it shuts down.
Mack sure it's level. some times that will cause noise. if it's still cooling, don't worry.
SOURCE: Loud thump from refrigerator when it shuts off???
If its a rattle, kind of a shake sound that ends in a phthump then its the compressor moving around after it has removed the heat from the unit. You may want new rubber mounts but I would leave it.
SOURCE: refrigerator keeps shutting off.Have to press
We have a solution to this link that will help http://www.fixya.com/support/r6019270-refrigerator_freezer_air_conditioner
