Hi I installed the Sony XPLOD CDX-GT200 CD player in my 1998 Dodge caravan and everything works, the radio, the CD player, but the display is not working. the knob and buttons glow red but the display is black. Ive cleaned the connectors and it still doesn't work. Any help would be appreciated.
SOURCE: Changing faceplate colors.
only the display changes colors.... your deck is doing what it was designed to do!
SOURCE: Cannot play my portable audio device with Sony cdx c500x
The multichanger has to be connected,with a cd in, but then the head unit will play whatever is fed to the bus in sockets. This effectively means the multichanger is playing to itself. If you want both to work, use a pair of piggy back rca leads into the head unit, one to the cd, one to the mp3. Then break into the cd leads and feed one of the pairs, one +ve, one -ve to a double pole switch so that you cut the sound from the cd allowing the mp3 in. To play cd's, flick the switch.
SOURCE: CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
SOURCE: need wiring digram for sony xplod cdx-gt200
Go to link below for manual on page 22 has wiring diagram.
http://akamaipix.crutchfield.com/Manuals/158/158GT200.PDF
SOURCE: Turning off sony cdx-gt170 display
Hold the volume button down until the clock setting comes on. Then press the same button until you see "Demo:On" on the screen. Turn the volume either up or down to change the setting and then hold the volume button down until you see "AUX" or "TUNER" on the main screen again.
