Question about Ricoh Aficio IS420 Flatbed Scanner
Ricoh Aficio 1027 stopped working
Whenever i try to scan it hangs up and doesn't do what it's supposed to
i checked the error logs and i get 3 errors
1. Launching of the scanner driver has failed
2. delivery type unknown
3. uinable to find file
everything was setup properly previously and nothing has changed and no one has gone into the configuration of it to make any changes.
it was setup as a network device and it was set to scan to a network folder.
I've tried turning it off and on, and restarting some services on the server that are associated with this specific device.
any help would be appreciated.
Thanks,
Posted by jonathanm19 on
  • Anonymous May 11, 2010
    What software were you using for scanning? Network twain? Scanrouter V2?
    Where do these messages appear? on your PC I assume?
    Did you scan from the machine by pressing the "scanner button", or from your PC via an editing software or similar?
    What happens when you touch the "scanner" button on the machine...does the scanner window appear, or not?
gggg
  • 904 Answers
You were able to scan okay before? If you can print but not scan, generally it's a firewall or permission problem. You could try creating an exception for the Ricoh in your firewall software.
The folder that you scan to hasn't moved, has it? Is the path still exactly the same? Try turning off your firewall and/or anti-virus software and see if you can scan then.
Posted on Jun 05, 2010
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
How to clear a sc546 error on a nashuatec 2705
It is the termistror problem.....the service you had to do is to read my document on servicing & changing of ricoh 1027/1022 termistor which i had posted 3 years ago
Sep 07, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
Tenho problemas na minha fotocopiadora Ricoh 1027,aparece no ecram código SC548.qual saida para situação
SC548: Fusing unit set error
Symptom: The machine does not detect the fusing unit.
Possible Cause: • Poor connection of the fusing unit
• The fusing unit is not installed
Jan 09, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027 what is the scan option part number?
The Printer/Scanner Controller Type 1027 part number is 411000 (product code B453), but I'm pretty sure that it's obsolete. Contact Ricoh customer service to find out if you can still order it.
Oct 07, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh aficio mp2000
Turn off the power for at least 5 to 10 minutes and then on. That code means that the main motor is locked.
Jun 01, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
Apr 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio IS420 Flatbed Scanner Logo
1,062 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
