For this and any other print jam problems try this;
Open the scan bed tray and push down the button at the front (scan bed tray open switch)
I found if your print jam occurs and you go through this procedure, the jam clears itself.
With the tray still up and switch held down, try and print something.
See how far the paper goes through the print cycle before jamming. If it jams when it reaches the print head...clean under the print head and try again.
Hope this helps
SOURCE: printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
SOURCE: wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best,
danakadan
SOURCE: I cannot get the Samsung CLP-310 color laser
Printers are only able to use paper that is within their thickness threshhold. Simply put, the stock you are using is too think for your printer. Try getting some thinner paper and see if that works
SOURCE: after setting the paper type to card stock to thin
This happens to be one of my least favorite printers.
Here is my suggestion:
Open up the cover and remove all 4 of the imaging units (with the toner cartridge). Also, remove the Fuser. While removing them, look for any bits of paper that may have gotten missed while clearing the jam.
Replace all of the items above and see if the printer still has a paper jam. It shouldn't.
Since, I assume you are manual feeding the card stock (the lower drawer doesn't allow for card stock to be used), look at the manual feed opening. There should be a small metal piece about 3" wide and less than 1/4" thick. Make sure it's attached properly. Ours unseated itself and is continuing to cause manual feed issues. This can be fixed but requires a good portion of the printer to be opened up to reseat the little metal piece.
Hope this helps.
SOURCE: paper Jam
Remove ink cartidge, undo clips first and give it a tug upwards, you should see the paper. Shut machine & restart.
