Question about Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP
Water pump 2006 mercury outboard water pump fix
Posted by richard kartch on
Bill Boyd
    Top Expert:
  • Seloc Master
  • 53,816 Answers
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
Posted on Aug 07, 2013
I have a 2006 mercury 115hp efi outboard...and I have a overheating issue. I notice there's no water exiting from the tale tell so I replace the thermostat and impeller and still no water from the tale...
was the impeller installed correctly for the drive direction
if not it will not pump water
next to check is the plate between the water jacket and the exhaust
that plate gets eaten away and allows the water to go straight out of the exhaust
Feb 14, 2018 | Mercury Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
What year is my mercury outboard searial no 3768233
Check here, you'll need the horsepower and lookup the serial-number range...
http://www.iboats.com/basics/serial_number_year.html#mercury
Aug 31, 2014 | Mercury Impeller, Water Pump - for...
Mercury outboard problems
Is this a two stroke?-If it is you most likely have a primary seal going bad (crankcase seal on the ignition side will lean it out,leaking seal on the other-side of assembly will do just what your describing)Hope this helps you out.....
Aug 07, 2014 | Mercury 4-Stroke 3.5 HP Outboard, Manual,...
50hp mercury marine outboard
put a water pump kit in it
May 26, 2013 | Boating
No tell tale.
water pump-
crack in the housing from sitting over the winter with water in it
Apr 14, 2010 | 2006 Mercury Mariner
Mercury 20Hp impeller/water pump location
It is located inside the lower unit housing. They are fairly easy to replace. Most Mercury authorized service stations will charge around $120 for this task.
Triton72
Mar 26, 2009 | Sport & Outdoor - Others
Seloc Mercury Outboard Engine Repair Manuals SEC-1416 1990-00 2.5-275 HP Logo
226 people viewed this question
Top Seloc Boating Experts
Marvin
Marvin
Bill Boyd
Are you a Seloc Boating Expert? Answer questions, earn points and help others
